Sponsored by: CARiD
will this be too tight?
Old Oct 29, 2006 | 06:39 PM
tweelow's Avatar
I own an '06 xl with a 2.5 inch spacer lift in front. I would like to put the biggest tire possible on an 18" rim. I was eyeing the Moto Metal 951's with the Nitto Terra Grappler 325/65-18, but i'm not sure it will fit without at least a body lift. I know another member put this size tire on his truck, but he's in a 4x4 and those have more ground clearance if I'm not mistaken. Anybody have a set-up like this, or does anyone know if this will fit, with minimal clearance issues....?? thanks guys!!
Old Oct 29, 2006 | 06:44 PM
TonkaTruck33's Avatar
it wont fit.. u would need more than just a body lift. a full suspension lift would work.
Old Oct 29, 2006 | 08:13 PM
allrsdup's Avatar
with just a spacer it will be a little tight that 325- 65 -18 is about 35x13
Old Oct 29, 2006 | 09:46 PM
Dog'em's Avatar
It really depends on how wide and what backspace your new wheels will have. That tire is 13" wide so you will probably need at least a 9" wide rim. Mottos don't have allot of backspace so you will have allot of rubbing in only a two wheel drive with just a levelling kit. I would think with the body lift you would be okay but I've never messed with two wheel drive trucks.
My truck has 35" tall tires but only a 285 for width, wheels are 9" wide but have 6" of backspace. No rubbing at all.
Old Oct 29, 2006 | 09:48 PM
tweelow's Avatar
do you think there would be enough room so that it could fit with some trimming?
Old Oct 29, 2006 | 10:03 PM
wandell's Avatar
Remember, he has a 4x2 that sits lower than a 4x4. I don't think he is gonna fit 325/65-18's on aftermarket wheels with only a leveling kit unless he is handy with a sawsall. They will probably fit with a leveling kit and a body lift.
Old Oct 30, 2006 | 08:08 AM
Dog'em's Avatar
Wandell is right, with a two wheel drive it's going to take both, the level kit and a body lift to run that wide of a tire.
