Sponsored by: CARiD
Procomp Lift with Body lift.
Old Sep 28, 2006 | 10:55 PM
Fordwitflows's Avatar
4" susp and 3" body lift
As most of you know I just had a body lift installed. Well, I knew it was going to happen, I want to go higher. The guy that did my install for the body lift said anything over 8" is hard to pass inspection in MA.
So, I was thinking. Procomp makes a 4" suspension lift for my truck. I was thinking about enjoying my BL during winter and after winter get the 4" Procomp put on. How does that sound? Will it work? What is the suggested tire size for a 4x4 truck with a 3" BL and 4" suspension?
Let me know what you guys think.
Also, from people who have lifted 6" or over. Besides lift, tires, and gears, what else did you have to buy to make the lift "work" Im sure brakes, but anything else?
Old Sep 28, 2006 | 11:10 PM
sean_somer's Avatar
i recommend the rancho 4" over the procomp
had it on my supercrew before i went with a fabtech 6"
thats all i did when i got my lift but i had already done my brakes
the only reason you should have to do your brakes would be if you got heavier tires and felt like your current brakes couldnt handle them
Old Sep 29, 2006 | 02:53 PM
What size tires do you reccommend with a 4" susp and a 3" BL
Old Sep 29, 2006 | 03:38 PM
spinnintires's Avatar
35's would look good with that much lift, if you were doing 6" and the bl i would say 37 is needed but with the 4" you would be perfect with some 35's!
Old Sep 29, 2006 | 03:59 PM
sean_somer's Avatar
i agree with spinnin
35"s should look great with a 4" & BL
