Can't find Lift Blocks for 06 F150!
I need to find a source for lift blocks for my 06 F150. I want to either add a 2 inch block or replace the stock block with a 4 inch block. The problem is every block I find has only 1 line up pin and the Ford blocks have 2. Can anyone give me a source?
I have been looking for lift blocks and U bolts as well for the 2006. I have a 4x2 and want to get some lift blocks for it, if you end up getting a 4" block, and are getting rid of the stock blocks (2") that came with your truck, let me know. I will be willing to buy them for you, and if i find a site that has lift blocks for it, i will let you know, the only site i found thats close is https://www.xmission.com/~liftkit/store/checkout.cgi and then click home and you should find them.
Call all of the major lift companies and see if any of them make a 4" block. I swear my Rancho kit came with a 4" block but I emailed them recently, due to a thread on here, and they told me otherwise. Its worth a shot though.
The only place I have found, other than Factory Ford 2" blocks, are Fabtech which makes the 2" block & the 5" block. No one else that I have found in my 2 months of research makes any other sizes......Iric
Well I ordered some that are supposed to fit. Found them at www.autopartswarehouse.com. Part # FTSBK2. I sure hope they work.
I ordered the 2 inch block. They are Fabtech and are supposed to have the double line up pin. We will see. The part # I attached is for the 2 inch.
Originally Posted by spinnintires
anyone know if those blocks will also work on a 4x2, i heard the pin setup may be different, you know if those will still work for mine, thank you.
Yes, they will work. The pin setup is the same. These are the blocks that came in the Fabtech 6" lift kit I installed & I have a 2WD. The Fabtech blocks are identical to the ones from the factory. I think that is where Fabtech gets them from.....Iric
O.K. this has been a major pain in the butt. The blocks I listed above came in today and they did not work,they have only one pin. The company I ordered them from had it wrong.
I called Fabtech and they have a 2 pin block but they are 3 times the cost of a 1 pin. I called the local Ford dealer and ordered the OEM blocks for $64.00 per set and I will have them Mon. or Tues.
I called the local spring shop and they will build custom u bolts for app.$15.00 a piece while I wait.
So I thought you guys would like to know this. Unless my math is wrong I will have the 2" rear lift for around $110.00.
