Sponsored by: CARiD
3"-4" suspension lift
Old Sep 19, 2006 | 07:55 PM
kAkA_r0Ach's Avatar
anyone know of ANY brand that sells a 3" or 4" lift? Dont want to go bigger because i dont want to go larger than 33" (tires) a body lift is out of the question............
any suggestions or info would be appreciated
Old Sep 19, 2006 | 08:36 PM
allrsdup's Avatar
rancho is 4" good lift in my opinion.
Old Sep 20, 2006 | 08:03 AM
wandell's Avatar
RCD also makes a 4 inch lift.
Old Sep 26, 2006 | 06:31 PM
kAkA_r0Ach's Avatar
thanks for the response guys but i checked both of them and they dont have one for my rig =(
2005 f150 s-cab 4x2
Old Sep 27, 2006 | 08:06 AM
wandell's Avatar
Sorry, we just assumed you had a 4x4.
Old Oct 1, 2006 | 12:28 AM
fordfanatic32's Avatar
I heard that procomp just came out with a 4in. lift but it might only be for four wheel drive trucks.
Old Oct 1, 2006 | 10:59 PM
JohnBoy88's Avatar
I was just about to start a thread about this.
I also have a 2WD. Can I get a 3" suspension lift for it? I personally don't like the look of body lifts.
I want a 3" suspension lift with 285/75R17 Open Country Toyo A/Ts. Is this possible for a 2WD? Also, does a suspension lift automatically level the truck or do I need to get a leveling kit in addition to the lift? Does anyone have pictures of a truck similar to what I want?
Thanks.
Old Oct 2, 2006 | 12:09 AM
cwbpro69's Avatar
They are not made for leveling spacers or kits, but many have done so with no problems...yet... I don't see why it should be a problem since you have a 2wd if you want to achieve more lift height.
Old Oct 2, 2006 | 07:58 AM
wandell's Avatar
Yes, you can fit 285/70-17's on your 4x2 with a 2.5 inch leveling kit and the OEM wheels.
Old Oct 6, 2006 | 08:15 AM
BlueOval Breath's Avatar
Howz'it KaKa Brah,
I spent tree years on Oahu in Kaneohe. I sure miss the islands. I did some research and found that Skyjacker makes a system for your 4X2. It is a 3" lift system and comes with new shocks. The p/n is F4321K and sells for around 610.00 dollars. Go to Skyjackers web site and check it out.
No okolepuka hear... just good ole boy! Shaka Brah.
Old Oct 8, 2006 | 03:07 AM
gatorade26's Avatar
Talking
Thanks.
I installed 3' lift spindles up front and 2" blocks out back which kept the factory geometry and let me put 265/70/17s which I think are 31" overall (pic). I bought both spindles and blocks together on ebay for about $300. This might work for you JohnBoy because we have the same generation F150....I'm not too sure if it will work on Kaka's current generation model. My $.02 cents
