Sponsored by: CARiD
lift or exaust
Old Sep 13, 2006 | 08:46 PM
kAkA_r0Ach's Avatar
lift or exaust
im going to get both done but wanted to know which one should be done first or does it matter?
Old Sep 13, 2006 | 10:26 PM
tex_n's Avatar
If doing a body lift, do lift, then exhaust. If doing a suspension lift, flip a coin.
Old Sep 14, 2006 | 12:21 AM
Redf150-2wd's Avatar
if you're doing either a body or a suspension lift, i would do the lift first then the exhaust either way
i had exhaust done, then got a body lift......so of course the pipes were hanging low bc of the lift
and then i had a suspension lift put on and ended up having to cut off the exhaust work bc the piping was rubbing on one of my rear shocks
Old Sep 14, 2006 | 07:51 AM
wandell's Avatar
I'd do the lift first.
Old Sep 14, 2006 | 06:49 PM
kAkA_r0Ach's Avatar
thanks for the feed back, well i guess its lift first, now i gotta bust my brains and decide in a levelkit/helper spring or a suspension lift =\
Old Sep 14, 2006 | 10:29 PM
allrsdup's Avatar
both
Old Sep 15, 2006 | 04:25 PM
ZR-900's Avatar
I did my exhaust first then did the suspension lift and had no problems.I'd
say the most important factor is the dept of your pockets.If you want a suspension lift it will cost alot more than the exhaust and the sound of a good exhaust system turns as many heads as the lift will.
[IMG][/IMG]
