Sponsored by: CARiD
What is the proper backspacing?
Old Sep 9, 2006 | 10:16 PM
DesertWolf's Avatar
How much would I need with 33/12.50/16's on a 3 inch lift?
Old Sep 9, 2006 | 11:04 PM
wandell's Avatar
On the 97-03 F-150's you need a wheel with 4 1/2 or 4 5/8 inches of backspacing. Do you have a 4x2 or 4x4?
Old Sep 10, 2006 | 12:48 AM
DesertWolf's Avatar
It's a 4x2. Just want to make sure there won't be any problems after I get everything together.
Old Sep 10, 2006 | 09:11 AM
wandell's Avatar
What type of lift are you installing? The reason I ask is that most suspension lifts for 4x2's increase your front track width a couple of inches. This makes 10 inch wide wheels stick way outside the wheelwells. Most 4x2's with suspension lifts that I have seen with 8 inch wide wheels have the front tires sticking out farther than the 10 inch wide wheels on my 4x4.
Old Sep 10, 2006 | 01:34 PM
DesertWolf's Avatar
http://cgi.ebay.com/ebaymotors/FORD-...temZ7955598526
This is the one I'm looking at.
Old Sep 10, 2006 | 02:29 PM
wandell's Avatar
Personally, I'd go with a 8 inch wide wheel. The spindles will increase your front track width.
Old Sep 10, 2006 | 11:37 PM
DesertWolf's Avatar
8" wide wheel with 4 1/2 inches back spacing? Would I run the same size rim front & rear? Just want to be clear.
Old Sep 11, 2006 | 07:49 AM
wandell's Avatar
Right. Most 16 and 17 inch wheels for our trucks have 4.5 or 4 5/8 inches of backspacing. Yes, you would use the same wheels front and rear.
Old Sep 11, 2006 | 10:47 PM
DesertWolf's Avatar
Thanks for your help. It is much appreciated!
