Sponsored by: CARiD
shock removal
Old Jun 6, 2006 | 09:42 PM
bmx150's Avatar
shock removal
is there a simpler way to removing the shocks than holdong onto the part that spins so i can fit in my new ranchos. this is for my front end and the hanger for the coils is right behindit so there is no hand room.
-dan
Old Jun 6, 2006 | 11:19 PM
lees99f150's Avatar
use a Blue tip wrench.
Old Jun 7, 2006 | 11:22 AM
DDan1967's Avatar
I've always just locked a pair of Vise Grips on the Crome shaft. If your trashing the old shocks it's not a big deal.
When I installed my Ranchos I did the same to install the new shocks too. Just make sure to lock on the shaft near the bushing. Unless there are some major suspention failures the shock will never compress that far anyway.
Old Jun 7, 2006 | 05:58 PM
kfleming's Avatar
ok what is that?
Old Jun 8, 2006 | 12:55 AM
bmx150's Avatar
the top half of the shock spins not the shaft is there a nut somewhere to wrench onto?
-dan
Old Jun 8, 2006 | 11:27 AM
DDan1967's Avatar
-dan
My bad, sorry I forgot that, it's been sometime since I've been tinckering on my truck, it's been in storage collecting dust since June of last year. I'm hoping that in a few months when I get home I can get it running.
Anyway, I remember what I did now. I used a LARGE slip joint wrench and crushed the cylinder to keep it from spinning. If you aren't reusing the shocks thats not a big deal. Otherwise you need a thin pattern wrench to get between the mount and the top of the shock cylinder.
Old Jun 8, 2006 | 12:16 PM
Bent6's Avatar
25 Year Member
It's the same thing as a smoke wrench (Oxy/Fuel). Burn it off It is fastest way to change shocks. With the salt used around here, sometimes it is the only way to get shocks off.
Old Jun 9, 2006 | 11:07 AM
jjmIII's Avatar
I'm starting to think my mechanic takes all bad parts off with the fire-wrench. That's how I know, he knows what he's doing .
Old Oct 26, 2008 | 04:02 PM
tomfilbey's Avatar
1997 f150 rear shock removal
Cut off the top nut with a reciprocating saw. I used a 9 inch bi-metal blade. Took me about two minutes.
Old Oct 26, 2008 | 04:30 PM
jbrew's Avatar
I broke everyone of mine. Pipe Wrench 10 mm and cheater pipe on the front. Couldn't get a cheater pipe on the rears., was able to break them with just the wrench.
Old Oct 26, 2008 | 05:39 PM
blackFX4ny's Avatar
I like the saw idea. I really need to buy a sawzall.
Old Oct 26, 2008 | 05:49 PM
jbrew's Avatar
That won't work on top. IMO
