Sponsored by: CARiD
Suspension help
Old Jun 3, 2006 | 12:01 AM
Quackaddict's Avatar
Suspension help
As I mentioned in a previous post I have a squeak in the supsension like I said when I hit a bump it is really noticable but makes it driving down the road. Sounds like a chain being jerked. Anyway narrowed it down to wheel bearing or ball joint.
How do I check to see these items to see what it is?
Old Jun 4, 2006 | 02:32 AM
ford tech's Avatar
i dont think your problem will the the wheel bearings, they
won't make noise over bumps, did you check the sway bar
end links and mounting bushings, if those are making noise you will hear it just driving down the road, easiest way to check is to just remove the sway bar links and drive it, if noise is gone you know its something related to sway bar
Old Jun 6, 2006 | 10:43 AM
thanks man nice to see there may be another option. I hate those noises that you don't know if it is a problem or not but the noise just bugs the living fire out of you. Not bragging but I have a nice truck and it sucks to drive it around and everyone says nice truck..........what's that squeaking noise I mean you can hear driving straight, turning, brakes have no effect but bumps sure do.
