05 fx4 lift question
whats the best way to level my truck? i've added alot to the truck and i just got some 20"s on it but i can't live any longer with the back end sitting up higher than the front.
is there a kit you can buy for the front end to raise it up to match the rear? also i have no truck shops close by so do i need to travel out of town or can my local ford dealer do this?
i plan on a small 3" lift within the next few months. that being said i do need to level the truck before the lift right? it seems like if i didn't the truck would just be 3" taller with the *** end up in the air that is unless lift kits correct the height difference between the front and rear...i'm un sure how this works.
thanks in advance.
thanks in advance.
You can lift the front of the truck with a leveling kit. The Autospring kit is popular among members of this site. It is simply a spacer that bolts on top of the front coilover shocks. What type of lift do you plan on installing? THe only 3 inch lifts I know of are the Skyjacker replacement coilovers and the Performance Accessories 3 inch body lift. You can combing the Autospring and the body lift, but not the Autospring and Skyjacker lifts.
