Sponsored by: CARiD
will this work?
Old Apr 3, 2006 | 09:32 PM
05Flynt's Avatar
will this work?
Hey guys i was wondering if i got the fabtech 6in lift if i could just use the stock rims or will they not work for some reason. i was gonna put some 35 or 37 on them and get the lift to save some cash right now then later on invest in some rims i like. if this will work let me know. thanks.
Old Apr 3, 2006 | 10:25 PM
-TXF150-'s Avatar
I would not reccomend putting 35's on stock wheels, although it can be done.. You would have to be to put 37's on stock wheels....
Old Apr 15, 2006 | 10:41 PM
JRERACER26's Avatar
35"s Should Be Ok On Stock Wheels, But They Are Going To Hit The Frame In Sharp Turns Because Of The Offset Of The Wheel. Aftermarket Wheels Have A Zero Offset, Where As Your Factory Wheels Will Set In Alot Further. 35x12.50 Or 37x12.50 Will Work If You Have Clearance.
Old Apr 15, 2006 | 10:44 PM
JRERACER26's Avatar
The Other Problem Is If You Have A 2004 Or Newer, You Have To Go With 17" Wheels Or Better Because Of The Brake Calipers, Which Will Make It Tuff To Find Tires. Look At The Bfg A/t Ko Or The Nitto Terragrappler. The Nitto Is Alot More Reasonalby Priced And Will Last Just As Long.
Old Apr 15, 2006 | 11:18 PM
crash_lucky13's Avatar
you can also go with the pro comp xterrains....have had alot of good reviews about them
Old Apr 16, 2006 | 03:44 PM
ws6_guyscrew's Avatar
its possible but would be better to get aftermarkets.
Old Apr 23, 2006 | 11:33 AM
FloridaCracker's Avatar
I was considering the same thing. The shop suggested using spacers between the rim and truck hub to deal w/ that offset issue mentioned above
