90 F150 need advice
90 F150 need advice
I just got (free) a 90 F-150 2wd with 271,000 miles on it. Motor and trans are original and have not been rebuilt. I wanted to start getting it more road worthy and begin with the suspension and steering. I was thinking of replacing the following things and wanted imput from you guys.
Coil springs
Leaf Springs
Shocks
All bushings (I have found bushing kits for 4wd but not 2wd)??
Ball joints
Camber kit
Anything else you guys would suggest?
Coil springs
Leaf Springs
Shocks
Ball joints
Camber kit
You may want to do wheel bearings and brakes too.
I don't recall if that model has twin I-beams up front. If it does, you may want to replace those bushings.
When I replace coil springs, I like the heavy duty versions. And don't forget the spring silencers.
