Lower Ball Joints the best choice?
My 1999 F150, developed a squeck while turning and over bumps. From under the truck sound seems to be coming from the right side lower ball joint. After reading some of the suggestions in this forum I've decided to replace both joints. Confused about what make of ball joint to buy. The moog K8695T can be greased, Delco 45D2221 and TRW 104222 are premium joints that are permanently lubricated. Any Suggestions?
Confused in Canada
Confused in Canada
squeeky front end
You know, many people overlook the pitman arm when looking for a squeek noice in the front end and immediately think ball joints. You can heat the joint with a good heat gun or propane torch if your careful. The heat will make what grease that is left run and the squeek will go away for a while. Do one joint at a time until you have located the squeek. Hate to see people spending lots of money when they don't have to. Good Luck
Lubrication is a good thing!
The other thing to do is to go invest in a grease gun needle (roughly $2.50).
Slip the needle up into the joints (under the rubber cover) and replenish the lube. Quiets the front end down immediately, and can't help but to lengthen the life of the joint.
Apparently I didn't do this to my F-150 soon enough (I bought it with 67K on it), but the '99 Expy has more miles and its front end is still intact (touch wood!).
The ball joints are actually cheaper at Planet Auto Parts:
www.planetautoparts.com
You'll have to search by part number, not by vehicle. Fortunately you can get all the part numbers from Rock Auto.
However, I must confess that I bought all the parts at my local O'Reilly so I'm not sure how good the service is at Planet. I could have saved about $60 had I gotten them at Planet but I wanted the truck for work the next day.
If you do the job yourself, be sure to borrow the ball joint press kit from either AutoZone or O'Reilly - you will need it.
This is literally about a 4 hour job and I really took my time. I cannot understand how shops can get away with charging so much for this!
Keith
Keith
This helped me.
http://www.ford-trucks.com/forums/sh...d.php?t=364301
Use a large tiewrap, or a piece of wire, to hold the axle shaft up and out of the way. And put the new balljoints in the freezer for several hours before you press them in. They go in real easy this way.
