Sponsored by: CARiD
autosprings install
Old Jan 4, 2006 | 09:27 AM
_SG's Avatar
_SG
Question autosprings install
Can anyone recommend an installer for the autosprings 2.5" leveling kit on an '05 F150? I am in McKinney, 30 miles north of Dallas.
Old Jan 6, 2006 | 10:36 AM
_SG's Avatar
_SG
BUMP
Old Jan 6, 2006 | 10:55 AM
The_Brute's Avatar
Any particular reason why you don't want to do it yourself? I just did a 6" Fabtech suspension lift on my own. Just take your time and I don't see you having any problems.
Old Jan 6, 2006 | 12:35 PM
04sd's Avatar
I did my own but any decent mechanic should be able to do it in 1-2 hours.
Old Jan 6, 2006 | 01:33 PM
f150Lariatc's Avatar
alot of times its just easier to take it in and take it out, but if u have the time i would do it yourself. plus will save u tons of money!
Old Jan 12, 2006 | 02:14 PM
-TXF150-'s Avatar
Hey man, I can help you out with the install, I have air tools and the stuff needed to get it done.
Old Jan 14, 2006 | 09:35 PM
_SG's Avatar
_SG
-TXF150- that would be awesome! I just got back from a business trip to the east coast, hence why I have not responded sooner. I'll pm you, and we can set it up.
Old Jan 14, 2006 | 09:44 PM
_SG's Avatar
_SG
Looks like PM is disabled, and your privacy settings prevent email. If you still offering the help (which is very cool), you can email me, and we can work out the details.
Old Jan 14, 2006 | 11:15 PM
runnerbl's Avatar
I need some assistance in Colorado Springs as well. Any good souls out there wanna help (teach) me?
Thanks,
Brian
Old Jan 16, 2006 | 03:54 PM
-TXF150-'s Avatar
Hey man, I am still up to helping you out!!
Old Jan 16, 2006 | 03:57 PM
-TXF150-'s Avatar
I enabled email, so email me and we can set this up.
Old Jan 16, 2006 | 06:02 PM
FUZZYDP's Avatar
My mechanic took 2 hrs including alignment. Cost $125 total.
Old Jan 21, 2006 | 12:49 AM
freekyFX4's Avatar
I installed my own and would say that anyone with half of a brain could do it without much problem. On the other hand, the Pro Comp Add-A-Leaf that I installed was a total PITA! I had to drop the exhaust and gas tank just to remove the leaf springs. I should have paid to have someone do it.
Old Jan 21, 2006 | 11:00 AM
runnerbl's Avatar
Mine just got delivered. It says that I will need an impact wrench to remove the lower strut assembly bolt (30mm one). Is this true or can you do it by using ratchet?
Old Jan 21, 2006 | 11:26 AM
runnerbl's Avatar
Would it be possible for someone to take pictures of the following so that I know which is which after I remove the tire...
1. Lower swaybar link attached to lower control arm.
2. Lower strut assembly bolt.
3. Upper control arrm to spindle
Thanks,
Brian
