autosprings install
Originally Posted by runnerbl
Mine just got delivered. It says that I will need an impact wrench to remove the lower strut assembly bolt (30mm one). Is this true or can you do it by using ratchet?
Originally Posted by freekyFX4
I installed my own and would say that anyone with half of a brain could do it without much problem. On the other hand, the Pro Comp Add-A-Leaf that I installed was a total PITA! I had to drop the exhaust and gas tank just to remove the leaf springs. I should have paid to have someone do it.
I bought a 30mm socket, labelled axle nut socket, from Advance Auto Parts and a long 1/2" drive "breaker bar" from Sears to put the socket on instead of a ratchet. It came off with no problem at all.
Well,
I was all excited to get these on. Went and bought jack, jackstands, breaker bar...got 30mm and torgue loaner from auto zone. Jack up truck, get my 18mm socket to take off nut from lower sway bar link. I can't get that bitch to move. My veins were popping out of my head. Is there a trick to this? If I can't get that off...I am wondering about getting the 30mm nut off...
Would it be possible for someone to take pictures of the following so that I know which is which after I remove the tire...
1. Lower swaybar link attached to lower control arm.
2. Lower strut assembly bolt.
3. Upper control arrm to spindle
Thanks,
Brian
Thanks,
Brian
