Sponsored by: CARiD
Level kit ?
Old Nov 24, 2005 | 11:42 PM
Synergy16's Avatar
Level kit ?
I have a 2004 f150 2wd 4.6 and i want to get a 2.5" level kit and i know i have viewd people saying not to get the daystar because it's plastic and to get the autosprings,but is it really all that bad and can i clear 305 or 35" tires without backspace?And should i get new wheels or run on stock?
Old Nov 25, 2005 | 10:29 AM
hmfic's Avatar
Either one is fine. I personally like the way the daystar mounts inside the coilover, I think that would be a stronger design. Most on this site preach the autospring. I have a buddy with the 2.5" tough country, which is the same as the daystar and he hasn't had any problems. If you want to spend a little extra money the 3" skyjacker is an option. I have it and love it. Plus it gets the back up a little bit, so when you hook on a trailer your nose isn't aiming toward the sky. The kits about $570 and its as easy to install as the daystar, besides you have to put the add-a-leafs in the back. (easy) Good luck.
Old Nov 25, 2005 | 10:45 AM
wandell's Avatar
They all do the same thing. The only advantage to the Autospring and similar designs is it is much easier to install. Also, since you have a 4x2, I'd stick with a 33 inch tire.
