Sponsored by: CARiD
Front and Rear "mini" lift
Old May 21, 2005 | 01:05 AM
metallicat's Avatar
Can someone please tell me the best way to lift and '04 F150 Ext. Cab about 2 - 2 1/2" up front and about 1" out back. All of the information that I can obtain would be great. I have seen that many of you are using the Autospring up front. Does anyone have a link? Does the kit come with everything that you need? Do they require an alignment?
As far as blocks in the rear are concerned, does anyone have a brand preference? Whatever kit that you recommend, does it come with all of the hardware? Please help. I have a buddy that is dying to do this to his truck but he has no internet access. You guys would be his heros. Thanks in advance.
Old May 21, 2005 | 10:28 AM
wandell's Avatar
I'd go with the Auto Spring up front and a lift block in the rear. Each truck seem to be a little different as far as how much lift a given size Auto Spring lift will give. I'd install it and then decide what size lift block you need in the rear.
Old May 22, 2005 | 03:04 PM
sirshan's Avatar
I agree with wandell...go with either some sort of spacer in front and do a block or add-a-leaf in the rear.
I know my FX4 had a stock block in the back...not sure what the size is, but say it was a 1" block, then you could replace it with a 2" or whatever you please.
Old May 24, 2005 | 08:55 PM
HotLap's Avatar
Wandell - where to get the Auto Spring, how much, what's involved?
thx!!
Old May 24, 2005 | 09:28 PM
blacklariatfx4's Avatar
I agree with the Autospring. I bought mine (2 1/2") from "springbender" for 119.00 shipped. It completely leveled my truck. Note that I do have the Westin Sportsman full brush guard up front. It's also an easy at-home job, just mounts on top of the original coil-over.
Take a look at my gallery for more pics.
Old May 24, 2005 | 09:34 PM
HotLap's Avatar
So then the AutoSpring would be a better set up than say the "Tuff Country"
spacers for the front? Is the AutoSpring a spacer as well? Where can I find SpringBender?
thx
Old May 24, 2005 | 10:32 PM
wandell's Avatar
Most members here bought their Autospring lifts off EBay.
Old May 25, 2005 | 09:23 PM
I apologize for the lack of clarity in my last post. I purchased mine from e-bay from Auto-spring, they do business (seller name) as springbender. They ask 119.00 including the shipping.
I can't say that the autospring is "better", it just depends on your preference. The main difference is that autospring, ez-lift and a few others use a metal spacer that bolts on top of the factory coil-over. The tuff-country, daystar and others use a polyeurethane spacer that sits between the top of the spring and the upper mount(requires more work). If you do a search, you can find many, many discussions debating which system is better. I really can't say either way, other than I am extremely satisfied with mine and I installed it in my father's garage using hand-tools.
Good luck, the key is to do some research and decide which one you want on your ride.
