Sponsored by: CARiD
Pitman Arm Removal ????
Old Mar 28, 2005 | 01:44 PM
dayalalito's Avatar
HOW HARD IS IT TO REMOVE/ CHANGE THE PITMAN ARM ???
(97 EXPEDITION 2 WD 4.6 L)
DOES ANY BODY HAVE THE STEPS ???
Old Mar 28, 2005 | 09:52 PM
Yankee7985's Avatar
Replacing the pitman arm is easy.
1. Purchase the new arm at your local parts store.
2. Purchase a pitman arm removal too, if the parts store does not loan them.
3. Crawl under the vehicle on the left side.
4. Remove the hardware at each end of the pitman arm.
5. Use the tool to remove the pitman arm from the steering gearbox shaft.
6. Replace pitman arm and reinstall hardware, with new cotterpin.
Old Mar 29, 2005 | 03:25 AM
bryanfeelsgood's Avatar
Takes about 20 minutes from what I hear.
Why are you replacing?
Old Mar 29, 2005 | 06:32 PM
Johngs's Avatar
On a 2wd its rather easy.
4x4 not the case (so I hear).
Old Mar 30, 2005 | 04:18 AM
Right, on the 4x4 there is something directly in the way (can't recall what it is), that must be removed first.
Old Mar 30, 2005 | 07:34 AM
Kurt_02F150's Avatar
spray it with pb blaster to make it a lil easier
Old Mar 31, 2005 | 04:39 PM
Dad's Hoss's Avatar
I did mine last year. Do a search by pitman arm and hopefully it will pull up.
