Sponsored by: CARiD
camber like crazy... help!
Old Mar 24, 2005 | 02:01 PM
average_boost's Avatar
I just dropped my 2004 fl50... there is horrible camber in the front.. I installed the djm lower and upper control arms.. and 2" coil spring.. like its so bad im affraid to drive.. and my tires look flat.. please help.. if i bring it to an alignment shop, can they fix it?
Old Mar 25, 2005 | 04:08 PM
colvin's Avatar
as long as you put it together right the shop should be able to fix it.if the tires tops are leaning out thats + camber and if there in its - camber,camber pulls to most + so what ever side is out more it will pull that way...
Old Mar 25, 2005 | 04:57 PM
HIDPLANET's Avatar
Should be able to align it up straight. Just got my drop back yesterday, front was 2 inches and its straight with no negative camber. The shop that installed the suspension has a state of the art laser alignment machine so they told me its back into factory specs. You can tell by looking at it that it is nice and straight.
Old Mar 26, 2005 | 02:27 AM
yeah they fixed it... it was cambering so hard i was leaveing rubber lines in the road... I drove on it all day... it rides great, thanks for the help
Old Mar 26, 2005 | 07:22 PM
HIDPLANET's Avatar
Good deal. Should come out like this:
