Sponsored by: CARiD
Torque specs
Old Jan 9, 2005 | 12:29 AM
Skoyen's Avatar
Question Torque specs -- nm, got 'em
I've been working on replacing lower ball joints in my '01 SCrew 4x4. Having not yet purchased a manual, I'm in need of some torque specs to put everything back together. I've been searching, but haven't found everything I need.
Here are the ones that are still in question:
spline shaft nut (is that the right name?)
tie rod end
half shaft bolts (to front diff.)
Any help will be greatly appreciated!
Stuart
*edit* Got 'em and truck is back together!
I love this site
Old Jan 10, 2005 | 01:40 PM
JMC's Avatar
JMC
25 Year Member
Stuart,
In the order that you asked;
The Front Axle Hub nut torque is 188-254 lb-ft.
The tie rod to the steering knuckle nut is 57-75 lb-ft.
The ½ shaft bolts are 60 lb-ft.
JMC
EDIT: Spelling
