Want to Remove 2" Coil Lift and Install Drop Shackles....
Well, I've tried the 2" coil lift for the past few months. I like the height of the truck but can't afford the stabilizers and beefy shocks needed to dampen the steering. I will be going back to the stock coil in the front with the drop shackles in the rear. To avoid another alignment cost, is there a way to align myself with the OEM coils?
Thanks,
Thanks,
Re: Want to Remove 2" Coil Lift and Install Drop Shackles....
Originally posted by OE812
.....to avoid another alignment cost going back to stock ride height, is there a way to align truck myself with the OEM coils?
Thanks,
Thanks,
I was thinking about getting the 2" lift coils....but now that you mention that I am thinking otherwise. I have a 04 4x2 XLT, new style, and I just ordeered the FX4 blocks for the rear and I have the autosprings 2" for the front. Well since this setup will still put me lower in the front 2" I wanted these coils. What else would I have to do to make it work? you mentioned new shocks? thanks
Bryan
Bryan
Originally posted by romeoz
I was thinking about getting the 2" lift coils....What else would I have to do to make it work? you mentioned new shocks? thanks
Bryan
Bryan
