front end spacers
front end spacers
I have a regular 2wd single cab 2001 F-150 and I am wanting to put spacers on the front suspension to level my truck so I can fit bigger tires. What is all needed to have other than the spacers.
All you need are the Daystar spacers. You may or may not need a camber kit to get the alignment correct after the lift. I think they run about $40 or $50. I believe that you cannot go over 2.5 inches of lift without replacing the upper control arms. 2.5 inches will get you close to being level.
