RCD or FABTECH?
WOW. ....about a $300 savings. thanks for that find.
"my old man is a tv repair man, he's got this ultimate set of tools.....I can fix it."...just a little quote from one of the best movies ever made..Fast Times at Ridgemont High
I have a pretty good stash of tools, I just don't know if I have the brainpower.
Well the directions are pretty complete so as long as you can read and follow directions you should be ok. There are a few things they did backwards so once your ready for the install post up and I am sure TX adn I can give you some tips on the install.
Richard
Richard
My old 98 Scab had the RCD 6 inch, and my friend has the 6 inch fabtech. Quality wise both are the same in my opinion. The only difference is the bilstein shocks that the RCD kit comes with. RCD's ride is much smoother especially on the road. If this kit is mainly for looks, go for the RCD kit b/c it will feel better on the road. Off roading go with the fabtech.
He will NOT get 6" with the RCD kit for two reasons first reason is it is only a 5" kit and secondly the Supercrews only get 4" out of there 5" lift. He can always upgrade to the Bilsteins shocks which is the only differance in the ride. I have ran the Fabtech shocks and they actually had a softer ride than the Bilsteins I am currently running.
Richard
Richard
And I was merely tryng to tell him tha facts regarding the RCD kit . It is only a 5" kit and the Supercrews only get 4" from it. Did not mean to make it seems as though you implied that.
Richard
Richard
Thanks, I have herd that they all are good lifts, each of them have there good and bad points, how ever I am attrated to the Sky Jacker for some reason... Dont know why. I just want one that comes complete and is reliable.. Still have alot of home work to do...
Fabtech very complete very reliable. I have a buddy who has the RCD and he has had numerous parts break. The Skyjacker kit does not come with brake lines either. Also it is only available in red.
Richard
Richard
