Alignment
Alignment
I just got the alignment for my truck done. Its better but still pulls(drifts) alittle to the right
Here are my current specs:
Left Front
-.09 Camber
5.3 Caster
-0.04 Toe
13 SAI
12.1 Included Angle
Rigth Front
-0.1 Camber
5.7 Caster
-0.17 Toe
13.4 SAI
13.3 Include Angle
I see that the right Toe is a little out of spec
I drive on the highway a lot so should I have them add some Caster?
Any recommendations to have them change that would help keep it from drifting right?
Left Front
-.09 Camber
5.3 Caster
-0.04 Toe
13 SAI
12.1 Included Angle
Rigth Front
-0.1 Camber
5.7 Caster
-0.17 Toe
13.4 SAI
13.3 Include Angle
wow they didnt even get the toe straight and the cross-camber is out of spec and i didnt see a thrust angle measurement the other things to do would be check ball-joints and idler arms like to have to much play sometimes cuasing a drift at times. also it may be a tire pull swapp from left to right the front tires see if it pulls the other way.
