Sponsored by: CARiD
performance accessories 3" question HELP!!!
Old Nov 16, 2003 | 02:25 AM
NickJ's Avatar
Unhappy performance accessories 3" question HELP!!!
Fella's,
Will a 3" performance accessories body lift for a '97 f 150 supercab fit on my '01 supercrew? I don't want to have to Jerri-rig anything, I just as well go buy the right one.
Old Nov 16, 2003 | 10:39 AM
wandell's Avatar
I beleive the Supercrew has more body mounting points than a Supercab, but I'm not sure. If it does, the kit for the Screw will include a couple more lift blocks and bolts. I can tell you that I've installed the PA kit on an 01 Expy and my 01 Screw. The instructions for the Expy kit were printed in 1997 and were nowhere near as good as the instructions in my Screw's kit. The instructions that came with my Screw's kit were more like a book. They had photos of almost every step. These instructions alone are worth buying the right kit for your Screw, especially if you've never installed a body lift before.
Old Nov 17, 2003 | 01:52 AM
frdstpsd98's Avatar
hey wandell, was it easy? I wanna get one one for my 98 F-150, and i know the PA's a really good body lift. I just dont want it to turn into a 4 day project. Thanks
Old Nov 17, 2003 | 08:13 AM
wandell's Avatar
Mine took me 2 days to install, basically working by myself. You will have to have a second person to remove and re-install the body mount bolts. The lift is not hard to install, it's just tedious and time consuming. There are a lot of small steps in the lift.
Old Nov 17, 2003 | 02:54 PM
Wolsiffer02Crew's Avatar
Hey Wandall,
My FX4 supercrew has factory 17's on it. Is it possible to put BF Goodwrench A/T tires on the factory 17's?
THANKS
Hey Wandall,
THANKS
Old Nov 17, 2003 | 04:09 PM
wandell's Avatar
Yeah, you can keep the factory 17's. There is a guy at FTW who has a 3 inch body lift on his FX4 with 315/70-17 (35x12.50) BFG AT KO's on the factory rims. It looks really good. You could mount those or the 285/70-17 (33x11.50) AT KO's. The 315's can usually be found really cheap. They are the OEM tire on the Hummer H2.
Old Nov 17, 2003 | 05:29 PM
frdstpsd98's Avatar
wandell, how did you make out with the shift linkage, the brake lines, and the gas lines, did you have to put extensions in? And what did you do about lifting the bed and cab to get the mounts out and in? I know how body lifts work, i just wouldnt know where to begin to install one. Thanks
Old Nov 17, 2003 | 05:32 PM
frdstpsd98's Avatar
Hey Wolsiffer02Crew, i have 33 inch BF Goodrich A/Ts on my stock 17 inch rim and i havent touched the hieght of the truck yet. They fit well and look really nice.
Old Nov 17, 2003 | 08:57 PM
Hey frdstpsd98, Can we see your truck? If you have any pics?
How much were your tires and where did you get them?
33/11.50/17 <~~~Is this your size?
THANKS
Hey Wandall, Does the 3" body lift change any brake lines, gas lines, steering stem or ect...??
THANKS
Old Nov 17, 2003 | 11:42 PM
frdstpsd98's Avatar
The 33's i have came on the truck when i bought it last year, i do have pics, but my scanner doesnt feel like working right now. Im guessing you can get them anywhere, Auto Zone, Pep Boys, anywhere that sells tires im sure. As for price, i think i saw them at Pep Boys for 170 a piece or something close to that.
Old Nov 18, 2003 | 08:21 AM
wandell's Avatar
I didn't have to touch my brake lines or shifter linkage. I did have to put the extension in my gas filler neck. I used a small bottle type jack to lift my bed.
Old Nov 18, 2003 | 05:42 PM
frdstpsd98's Avatar
Thanks, i think im gonna get one now, did the gas filler extension come with the kit?
Old Nov 24, 2003 | 08:56 AM
kev's Avatar
kev
Yes it does.
Although the hose for the gas overflow was the wrong diameter in the PA kit (at least for my truck - it is a 99). I had to pick up some the correct size.
kev
