Sponsored by: CARiD
F#(k!n S#!t......Bent Frame!?!?!?......Help
Old Jun 25, 2001 | 03:10 PM
FordYamaha's Avatar
Angry F#(k!n S#!t......Bent Frame!?!?!?......Help
I was looking under the rear of my truck when I saw that the frame right where the bump stops are mounted is bent up and bowed out on both sides.
I know it is from hard bottoming of the rear axle when I am off-roadin.
Also my bed and cab don't line up perfectly.
Has anyone had this problem before?
You might want to check it out!
What can I do to go about fixing it?
I guess it's time to get a set of NATONALS!
L8..Thanks for any help.
99 F-150
4x4
5.4 Triton
Old Jun 25, 2001 | 06:33 PM
MitchF150's Avatar
Red face
Bummer..... Have not heard of this before on this site. You must have been "flying" your rig some too? Always wanted to do that, but still owe too much on it!!
You should just take it to a frame shop and have them check it out. There should be specific "check points" built in to the frame that they can line up on to tell how outta shape it is. Then they can "usually" bend it back, but it will never be the same again...... Sorry.....
Good luck
1997 F150 4x4 XLT, SuperCab, Short Box, 5.4, Royal Blue/Silver, K&N, Gibson SS, LT265/75/16 Wild Country APT's, Hellwig Progressive Springs (LP-25)
Old Jun 25, 2001 | 08:52 PM
Ford4ever's Avatar
Post
I guess it's time you installed some stiffer springs and shocks huh? I have Superlift add-a-leafs and Rancho RS5000's in the back and i have never bottomed the back out. I've only bottomed out the front tires once against the fenders but that's because i'm running 35's when i should only be running 33's. I jumped the truck about 2' off the ground when i did that though
-Jon
Old Jun 26, 2001 | 02:07 AM
FordYamaha's Avatar
Question
Has anyone actually looked under their truck to see if yours is bent a little too? It is real hard to notice.
I think that others must have this problem also, but mabey not.
Just lay under their and check the rear bumps.
Thanks for any info.
L8
Old Jun 26, 2001 | 02:25 AM
MitchF150's Avatar
Post
I'm not sure if this shows enough of the stop, but here's a pic showing my helper springs. It kinda shows the bump stop. Is this where yours is bent?
Old Jun 26, 2001 | 03:06 AM
FordYamaha's Avatar
Arrow
Yes. It looks like yours is strait though.
The thickness of the frame pops out a little and is slightly bent up right where the bump stops connect.
It looks like you can replace just the back section of the frame, but I probably will have it bent back and straitend.
Old Jun 26, 2001 | 07:33 PM
Ford4ever's Avatar
Post
If you do a lot of jumpin around with your truck you might want to box in the frame, at least the area near the bumpstop. Most of the muscle car guys do this to keep the frame from twisting when they hit the gas. If you did this it would pretty much double the strength of your frame back there. Just be careful welding next to the gas tank
-Jon
Old Jun 26, 2001 | 09:08 PM
FordYamaha's Avatar
Arrow
Yea that sounds like a good idea!
I Probably will have the frame pulled back a little and then box it out like you said.
Thanks for the help.
99 F-150
4x4
5.4 Triton
