Sponsored by: CARiD
Body Lift Decreases Value?
Old May 31, 2001 | 02:00 PM
Paul919's Avatar
Post
Well, I just got my lift put on turns out my problem was that the machine cut the steering extension wrong so getting new on monday. Other than that there is no problems. Yes, your liner makes it a bitch to do. There is a signigicant difference in height trust me i'll get my pics soon. I will recomend getting LIPS for it. And no there is no change in motor or any other thing cuz ur just lifting the body not touching anything else. But, maybe raise the fan shroud but nothing to hurt anything. Sounds like he just doesn't want to do it they can be a bitch to install.
1998 Ford F150 4x4 OFR
Moonlight Blue
Short Bed Flareside
Dual exhaust Staight Pipe
Hypertech Chip
Fiberglass Tonuea Cover
3" Performance Acc. Body Lift
DON'T JUST DODGE IT STROKE IT FORD!!!
Old May 31, 2001 | 02:36 PM
powerstroke73's Avatar
Post
Sounds to me like he's blowing smoke. You don't change anything with the engine besides modifying the fan shroud. The only way you might have a problem is when you lift it the radiator would be right behind the bumper and have some air blocked going to it, but this is easily fixed with electric fans. The rhino liner will be a problem for putting the lift in if it was sprayed over the bolts in the bed. Rhino liner is really tough stuff. But sounds like hes just being lazy, your lift won't change ANYTHING in the driveline, all you're doing is lifting the body off the frame.
1997 F-150 Lariat
Ext Cab Short Box
4x4 Off Road Package
3.55 Gears
285/75 R16 Kelly Springfield Trailcutter RTs
My 2 cents worth
If you're gonna stroke it, POWERSTROKE IT!!!
http://www.powerstroke73.homestead.com/
Old May 31, 2001 | 06:36 PM
Donate54's Avatar
Post
hes blowing smoke up your a$$ because it is going to be a bitch to put on with the bedliner. the body lift wont be any harder on your truck than original, what makes it a little harder on your engine and tranny is the change of tire size. this problem can be overcome by matching the tires with a lower set of gears for your rearend. all i can suggest is to get a second opinion from another shop. worse comes to worse, you could always have the shop just rip the liner around the bolts off, then have those areas re-sprayed. good luck!
1989 F-150 XLT Lariat: 2WD 302 5spd[*]Performance Accessories 3" Body Lift[*]33x12.50.15 BFG A/T's on 15x10 AR Rims[*]Rancho Steering Stabilizer[*]Rancho RS 5000 Shocks[*]K&N Air Filter[*]Gutted Cats with Straight Pipes For Now...
Go Full Speed or Go Home!
Old May 31, 2001 | 06:51 PM
Ford4ever's Avatar
Post
He's full of it it can't void warrenties, check into the magnesson-moss warrenty act. Bedliner is a bitch but he could cut around the bolts or touch it with the torch and melt it, then you touch it up later. Get the body lift installed, but have it done by a different shop.
-Jon
Old May 31, 2001 | 06:55 PM
G Patricio's Avatar
Post
My last F150 had a Rhino Liner before I installed the body lift. The guy who shot the liner told me to simply cut around the bolts with a sharp utility knife. He said that since they don't take a grinder to the bolts, only the paint, it should easily come off and it did. It was easy to cut around the bolts, because the factory bolts are round (torx). He said I could come back and they could reapply the liner to the holes, but I never did. It didn't really look bad, and since I had a shell, I wasn't too concerned with moisture getting in.
As far as value, check out your local paper or truck trader for similar trucks on sale with lifts. You'll find that the decreasing value statement isn't true.....
Old May 31, 2001 | 07:48 PM
Crotteau's Avatar
Post
I would have to agree with everything above. Besides, you Rhino Liner can be resprayed in the spots where the holes were cut for the bolts. No, the **** won't be torn out of the bed if the body shop knows what they are doing.
Unless you trust this shop, go somewhere else or look into doing it yourself.
Crotteau
1997 F150 4x4
4.2L V6
Open Filter Housing
K&N Filter
Factory 5-Speed
3.08 Gears
3" PA Body Lift
305/70/16 Goodyear AT/S
16x8 American Racing Baja
Old Jun 1, 2001 | 12:36 AM
2dollarsteak's Avatar
Thumbs down Body Lift Decreases Value?
Yesterday I went over to my local body shop to see how much they would charge me to put a body lift on. They prices me $400 with everything including the lift lips. As I was there I began talking to the owner of the shop to see what he had to say about the lift. He told me that since I have a sprayed in bed liner over my bed bolts that he was going to have to "tear the **** out of it" to get the lift on. He said it would leave permant holes in my bed liner making it look "like ****". He also said that the lift would decrease the value of my truck when I decide to trade or sell it. He said he did not recommend putting one on at all. He went on and on about how it would void certain parts of my warranty and how the lift wouldn't even make a noticeable change. He told me that it would be hard on my motor, transmittion, and everything in my truck to put this lift on. Is he really telling the truth? I mean if the Body Shop is telling me this bad stuff about their own product, then really how bad is a Body lift for my truck. All the quotes I put in this message are HIS EXACT WORDS!! Was this guy just having a bad day or is this true that it will mess my whole truck up??!?!? Please help, anyone! Thanks.
My F-150
  • 2001 XLT
  • Toreador Red
  • Extended Cab
  • 4.6 Liter
  • v8
  • No Muffler (Illegal) NEW
  • Dual Exhaust (Y-PIPE)
  • 6" Chrome Tips
  • Vent Shades
  • AVS Blackout Headlight Covers
  • Rhino Sprayed-In Bedliner
  • Flareside
  • 20% Window Tint (Front 2 side windows)(Illegal)
  • 11" 7% dark tint band on front (Illegal)
  • Bugflector
    Pending
  • 295/75/16 BFGoodwrench All Terain Tires (June 2001)
  • 3" P.A. Body Lift (June 2001)
THE BEST TRUCKS ARE BUILT FORD TOUGH
Old Jun 4, 2001 | 09:23 AM
JMTruck's Avatar
Post
Decreasing value could be true depending on what the truck is going to be used for. I am keeping mine for a long time so all this add ons are increasing value from my point of view and personal taste.
Body lift will not hinder performance by itself (not very noticeable). But, since it is taller you will have a larger frontal area so you will have more drag. But this is not suppose to be a big difference. Now, taller and wider tires with no changes in your gears will make the biggest impact in performance and fuel economy but this is another modification and no part of the body lift.
Body lifts installations are very time consuming and pricey but try to get a second opinion. Have you considered doing it yourself? It's fun at the same time if you have the tools, needed space and patience. Friends could help.
Good luck in your quest.
My Ride: 1998 F150 4x4 Lariat Supercab Flareside 5.4L in Oxford White/gold, ORP, Tow Package, 3.55 Gears.
Modifications:
Optima Red Top Battery
Split Fire Spark Plugs
K&N FIPK
Gibson Supertruck Exhaust System
Stepshield door sill protectors
Performance Accesories 3" Body Lift
Performance Accesories Lift Lips by Mountain Enterprises
Superlift 3" lift blocks
Gabriel Gas Ryder LT VST Shocks
Daystar Front Anti-sway Bar Polyurethane Bushings
Heckethorn Steering Stabilizer
35x12.5R16.5LT BFG All Terrain KO's
16.5x9.75 American Eagle 589's.
McGard Premium Wheel Locks
Photos at: http://www.communicomgroup.com/jmtruck
