Sponsored by: CARiD
More Power
Old May 20, 2001 | 02:36 PM
4RDPWR's Avatar
Post More Power
I want to know the best ways i can get more power out of my truck. i have 285's on it. i want to regear it and put a chip in it. any info would be great on what kind of gears and chip or anything else
F-150 2000 Reg. Cab
4.6 manual
K&N Air Filter
Old May 20, 2001 | 02:45 PM
Matt90GT's Avatar
Post
Gears are expensive. The rear is not bad, but the front will make you bend over. The 4.6 has the 8.8 rear and uses the 8.8 reverse rotation gears up front for the IFS.
Cost is about $1200 from what I have heard. I would go 4.10s or 4.56s if you are going even larger.
For power, first open up the air intake. Cut the stock airfilter box in half, that removes one snorkle. Take the TB to MAF hose off, and take out the silencer there. install a K&N filter and you will have a similar setup to the airraid, K&N, airforce kit for the cost of a filter.
Exhaust, at least put a free flow muffler in place of the stock muffler if not a cat-back system.
Forgot to add an electric fan is a easy way to free up HP and get better MPG at the same time!
After that, you can run a larger TB and MAF. Expect about 5% hp gain from those 2.
A chip is good. Superchips is the way to to. Check with Mike Troyer for info and purchasing. Only bad thing about them is you need to run premium fuel or get a flip chip. An alternative is the Hypertech power programmer. it is device you plug into the computer and program it the way you want. You can calibrate for larger tires, gears, fuel rating, tranny shift points, speed limiter, etc. Basically the same as a chip, but you can program what you want and change it as you want.
Other things are power pulleys, PI heads, superchargers. Just depends on the budget and power you want.
[This message has been edited by Matt90GT (edited 05-20-2001).]
