Sponsored by: CARiD
Clunking Noise
Old Sep 10, 2003 | 06:28 AM
Jackie's Avatar
Unhappy Clunking Noise
A little help please! Driving 01F150 4x4- when turning left you can hear a clunking noise from front wheel well. What is the problem?
Thanks in advance,
Jackie
Old Sep 10, 2003 | 07:43 AM
MANDRAKE27's Avatar
Solution Move small chevy out of your way.....invariably they clunk when you drive over them.
Seriously though it could be a couple of things. Is it only when it is in 4x4? If not likely a ball joint or wheel bearing
Old Sep 10, 2003 | 07:44 AM
MANDRAKE27's Avatar
Ps are you running stock tires? check for rubbing
Old Sep 12, 2003 | 01:25 PM
ffdemoss's Avatar
check your left side a-arm rear bolt. See if it has appeared to move (paint/wax scratched off) Let me know what you find
Old Sep 13, 2003 | 01:32 PM
98lariat4x4's Avatar
Jackie,
I have the same thing happening to me. I had to have my lower ball joints replaced at 55K and that seems pretty typical for the non geaseable factory ones. When I had them replaced it helped some but I still have it. I have a slight, going in a straight line, bump induced clunk in the passenger front and a left hand turn induced clunk in the driver front. I wish I could figure these out and fix em, they are driving me nuts. All the suspension shops I take it to have the same story. "Everything is tight in the front end, it is in great shape"
Old Sep 20, 2003 | 10:55 AM
Black Truck's Avatar
The clunk I had turned out to be a loose shock bolt causing the problem. By the way, my ball joints had to be replaced at about 66,000 miles.
Old Sep 22, 2003 | 01:25 PM
ffdemoss's Avatar
Was it your top or bottom shock bolts that were loose?
Old Sep 23, 2003 | 04:27 PM
I think it was the bottom. The mechanic tightened it.
Old Sep 26, 2003 | 07:05 PM
Johnny Kay's Avatar
Smile
Jackie: check my posts under Ball Joints (Suspension Forum) and look under SuperCrew Forum for posts re: similar problem you've encountered. I got my "thunk" fixed under my extended warranty.
Good luck.
Cheers
Johnny (Canuck) Kay
Old Sep 27, 2003 | 04:24 PM
MANDRAKE27's Avatar
Hey Johnny Kay I was just golfing down in Welland yesterday.....At riverview gc Great course for the price....Nice to see fellow Canucks on here Cheeers!!!
