Just so ya know (Fabtech)
Ok guys and gals, The Fabtech spindles and 2 inch blocks have been on for two weeks now. I have had a few conditions that required attention, and thought I would pass it on.
Track width: In case ya didnt know, the new style Fabtech spindles are different from the older ones. My track width from the outside of the tires in the front is now 81 inches, (with stock rims). The unmodified rear is 77 inches. A difference in front to back of 4 inches is alot. Im not sure what the front was before the lift, but I'm sure it must have been close to the rear. The 3.5 inch lift I gained on the day of the install is still here. I suppose I will have to add some sorta spacers and longer wheel studs to the rear to make it look right. Anyone have any sources for quality spacers and studs?
Snap, crackle pop:
Since the install there has been a pop and tink from under the truck when it goes up or down in a tight turn, driveways and drive throughs, stuff like that. I was thinking the new spindles trashed my ball joints or something, the metalic click, pop and tink was very nerve wracking. Well rest easy, the cure was a dab of grease on the spindle to lower control arm turn stops. Just dip a lil grease on that metal nub that is attached to the back of the lower control arm and she will make those tight steering feats with ease again.
Oh well, just thought I would pass the poop.
Drive it like ya stole it! http://www.geocities.com/terrydeaton.geo/index7.htm
Terry Deaton
99 F150 XLT, 2WD, 4.6, S/C, S/B, Superchip, K&N FIPK, FMS 9mm, +4s, Nerfs, Leer Top, Cow Catcher W/Bright A$$ Lights, True Duals with hi flow cats, 275 Dunlops with 3.08 gears, fat swaybars, Steeda front and Hellwig rear, Fabtech spindles with 2 inch blocks, B/E Performance Shift kit.
Coming Soon: 4.10s and Auburn Diff.
96 SVT COBRA (almost stock)
98 AERO black w/lotsa chrome
Speed Kills, drive a Chevy and live forever.
[This message has been edited by TREADMARKS (edited 10-31-2000).]
Snap, crackle pop:
Terry Deaton
Hey, did you do the lift yourself? If so, how hard was it and how long did it take you? I am intrested in either the spindles or the 3.5 coil/control arm lift. And how much did you pay for the kit?
1998 Ford F150 4.2L V6
American Racing Rims
Brush Gaurd
Tinted Windows
Saving for lift and Air Raid
Brush Gaurd
Tinted Windows
The kit was 450 from RV Performance. Yes I did the install myself. I was not expecting the 3.5 inch increase in track width. It only took a couple hours for the front, but the rear took longer because the pins in the blocks were too small and I had to have a machine shop fix them for 20 bucks.
The spindles did lift and seperate (like a wonder bra). 3.5" up and 3.5" out.
Terry Deaton
Terry Deaton
Kial,
The Fabtech spindles and blocks and U-bolts was 450, delivered. Camburg couldn't touch that. I do like the upper control arms and Eibach coils that Camburg offers, and may purchase them in the future. I am begining to like the wide and tall stance that the wonder bra spindles has on my truck. It also seems to remain more flat in the turns now.
Now if I can just get the rear to match....
Drive it like ya stole it,
Terry Deaton
99 F150 XLT, 2WD, 4.6, S/C, S/B, Superchip, K&N FIPK, FMS 9mm, +4s, Nerfs, Leer Top, Cow Catcher W/Bright A$$ Lights, True Duals with hi flow cats, 275 Dunlops with 3.08 gears, fat swaybars, Steeda front and Hellwig rear, 3.5" Fabtech spindles with 2" blocks, B/E Performance Shift kit, Steeda Billit Pedals.
Coming Soon: 4.10s and Auburn Diff, Eibach Front Coils and Add a Leafs, Underdrive Pullies and Kick A$$ Shocks.
Terry Deaton
I have the ProComp spindles & they moved the wheels out 1" per side. I think most trucks & SUV's come from the factory with a wider track width in the front vs the rear. You don't want to use spacers with hub centric wheels. You'll make them lug centric & will have vibration problems.
97 F150 XLT, 4.6, auto trans, 2WD, ext cab, flareside, Leer cap,Teal
MODS:
3" Pro Comp spindles
285/75R-16 BFG's
Replaced chrome Grill, Bumpers & Mirror Backs w/ paintable types
4.30 gears
Red Line oil in trans & rear end
Front Receiver Hitch
MODS:
285/75R-16 BFG's
4.30 gears
I also installed Fabtech 3 1/2 lift kit.I also had a cracking and thunk sound. Found that rearend need to be align with the drive line. added 3 degree shim below 3" block at the rearend to get the right degree of angle to match the driveline using degree indicater which you can buy for few bucks at any auto store or you can use digital protractor to be more precise.
I hope this info helps
hmiz-
Where did you get the shim?
'98 F150 S/C 5.4 V8 4x2, Aggie maroon, spindle lift, blocks and leafs, Rancho RSX shocks, Airaid filter system, Pro Comp 305/70/16, AR Baja 16x8, Dynomax duals, and some other stuff
I know this is an old topic but I figured I'd bring it back to life because I think Fabtech Spindles and 2" blocks is a great deal. Where is this RV Performance? Do they have a website? Thanks.
I was just wondering the same thing.
1999 super cab
white with tan bottom
4x2 automatic
4.6L v8
BFG AT TA KO 265/75
WAAG grillguard
2 KC daylighters
vampire remote start combo alarm
steelhorse nerf bars
Husky chrome toolbox
4 pioneer 3 way 6x8's
wants: 2 chamber flowmaster dual exhaust
tan fender flares
american racing atlas
2" fabtech suspension leveling kit
1999 super cab
4x2 automatic
4.6L v8
BFG AT TA KO 265/75
WAAG grillguard
2 KC daylighters
tan fender flares
