Need help with cam bolts for a 2wd!!!!!!!!!!!!!
I just put a 3.5" spindle lift on my truck but I can seem to figure out if the cam bolts go on the upper or lower control arms. Can anyone please help!
1998 F150 Triton 5.4L (4x2)
K&N Air Filter
Pioneer 4100 W/remote
2\10" Rockford Fosgate Punch He. RFP4310
CatBack system with Magnaflow system 3" Pipe
3.5" Fatech spindle lift with fabtech shocks and 1.5" rear blocks
3" Performance Acc. Body lift, with lift lips
Xenon HID Super Whites 9007's
Front Clear Corners
Sonnax Line pressure modulator kit model#AX4N
K&N Air Filter
Front Clear Corners
Nacho,
The bolts go on the upper control arms. Remove the old hardware and install the bolts with a cam washer and lock washer on each end. Turning the head of each bolt manipulates the control arm in or out. Just center all four bolts and tighten them up. Of course, you'll need an alignment.
G Patricio,
Thanks for the help im going to work on it this weekend!!
K&N Air Filter
Front Clear Corners
K&N Air Filter
Front Clear Corners
