Sponsored by: CARiD
Suspension Lift Question
Old Aug 25, 2003 | 06:21 PM
NoName's Avatar
I have a 1999 F150 and am looking into putting a 6 inch suspension lift and 35 in tires on the truck it has 80,000 miles on it. If i did the lift what type of problems would I be running into down the road. What type of abnormal wear and tear would be caused by the lift and tires.
Thanks for the help.
Old Aug 25, 2003 | 06:34 PM
NoName's Avatar
Also is this setup to big to run stock motor and gears and still pull a trailer, that is about 5500 lbs
5.4 L of course
Old Aug 25, 2003 | 07:43 PM
rkjerue's Avatar
Hello NoName,
You may want to gears more appropriate for 35" tires, 4.10 or even 4.56 would be a good choice, also getting a SuperTuner to reset your trany and speedo will make your life easer. Doing these 2 things will help eliminate a lot of the drive train stress the larger tires can cause.
Old Aug 25, 2003 | 10:54 PM
NoName's Avatar
How much lift..... and what size tire.... would you guys suggest if i wanted to stay with stock gears and remotly stock motor
"Bolt on Stuff"
Thanks for all the help.
Old Aug 28, 2003 | 12:45 AM
rkjerue's Avatar
Hello NoName it's me again,
In my opinion a 4" lift (Rancho's is the best) and 33" tires are about the max for stock gears. Good luck!
