Sponsored by: CARiD
Steering Stabilizer/Bump-Stop/Shocks Questions
Old Mar 24, 2001 | 03:24 AM
BigBadRedLiftedFordMan's Avatar
Question Steering Stabilizer/Bump-Stop/Shocks Questions
Ok, first off...I am looking for 2 new shocks for the rear and really like the idea of the RS9000 remote control system. Problem is, a year ago when i was involved in a collision, insurance bought me 2 new shocks for the front and they are not near worn out yet. I am wanting the remote system because i load the bed with up to and over 500 lbs sometimes and the ride is obviously affected. I wanted to know if this system will help the truck sit more level if i adjust the shocks to their stiffer settings when loaded down. However, what my biggest question is: Can i buy the remote system to work only on the back (is that an option because i really only need to adjust the back) or must i go with the entire 4 shock control kit. If i must go with the 4 shocks, is there anyway i can just not hook up the front two right now? And is there a cost difference?
My second question is steering stabilizers. Like i said, i have 35s and that effects steering some to. I am looking for a cheap but reliable steering stabilizer. I'm a fair mechanic so if the instructions are good, i can do the install myself. What do yall recommend?
Last questions is: if you have lowered your bump-stop(by that i mean, making them longer), how did you do it...with the new setup, my tires hit my body b4 they hit my bumpstops, and i would like to keep my truck from destroying itself...thanks again yall for your help.
-Brandon Warford
97 F150 4x4 Sport Brt. Red SuperCab
4.6l Triton V8
3.55LS
3" Performance Acc. Body Lift & lift lips
1-1.5" torsion bar adjust. so it sits level
Clear Corner Lenses
315/75R16 Yoko. Geolander MTs
American Racing Atlas 16x10
Pioneer 8000 3D series
Boston Acoustic 5x7s
Sony Xplode 4ch Amp
(2) 8" RF XLC Subs
True Dual Exhaust
--(2) Stage 3 Flows (Exits like the Lightning)
Custom 4x4 Sticker
Viper Alarm
FUTURE MODS:
4.56 gears
Repaint around Headlights where clearcoat is coming off >=(
Possibly a Manik Brush Guard and Roll Bar--we'll see
Thats about it for now!
Killintime4fun@aol.com
"THROUGH the river and OVER the woods to grandmother's house we go."
"...the road curves to the right and there are a lot of signs that say you cannot turn left...TURN LEFT."
Old Mar 24, 2001 | 11:10 AM
JonC's Avatar
Post
Red... I just bought and installed the stabilizer kit made by Heckethorn. Installs easily and helps smooth out bump steer significantly. For $59 delivered in 2 days, I'd recommend it! I had spoken with Rancho also but they couldn't tell me if their kit would work with my truck and Fabtech lift, so I opted for Heckethorn. The stabilizer is a heavy duty, big-bore unit and comes with all mounting hardware and a rubber boot, color of your choice (Shock is white)
I answered a question earlier about installation for ilmagill in another topic, so maybe I'll get the digital camera out and snap a couple pics later on today. Looks good!
Hope this helps!
-JonC-
PS... glad to hear you got your tweaked axle fixed!
[This message has been edited by JonC (edited 03-24-2001).]
Old Mar 25, 2001 | 11:24 AM
busejag's Avatar
Smile
Hi..just thought i'd comment on your concern about levelling your truck when loaded. I have the same problem but unfortunately, putting adjustable shocks will not cure your quest to level your rear end when loaded. Although selecting a stiffer setting when fully ladden would help control excessive bounce, your truck would still end up with a rear end sag. Have you considered air bags? Hope this helps.....
Old Mar 25, 2001 | 02:43 PM
ilmagill's Avatar
Post
You could also use helper springs. Then you'd get the extra springs without sacraficing ride while keeping the rear the same height.
Old Mar 25, 2001 | 02:49 PM
Maximum Overdrive's Avatar
Post
What if you found the rear-air bag system that they put on the 97-99 LD F-250's? I know it works on mine... Go to a scrap yard or something and find some. Other than that, I agree with busejag, they wont do much other than to empty your pocket book.
1997 F-250LD Super-Cab Styleside 4x4
  • Bright Red Clearcoat Metallic
  • 5.4/L V-8
  • Heavy-duty everything
  • 3.73 Rear End
  • Manual 4x4 floor shift for increased reliability
  • Soft tonneau cover
  • All-Star Bedliner
  • 5th Wheel Hitch
  • Keepin it stock! ;-)
Future Mods:
  • Superchip
  • Goodyear Wrangler AT/S Tires
  • K&N FIPK
  • Super-White Headlights (when the current ones go bad)
  • Lighted Ford Logo for the front Grille
  • Ford Hitch Cover
  • In-dash CD reciever, upgraded speakers
Other Toys:
  • 1994 Kawasaki Bayou 220
  • 1997 Yamaha Zuma-II Scooter
  • 1978 Arctic-Cat Jag 3000 F/A
My Collection of Funny Pictures and other Various Humor related items!
Contact:
rockerc@mediaone.net
AND
on AOL: LeAdFoOt415
Chris4wheeling's Avatar
Post
ok the RS9000 wont help u level the truck when loaded. it just controls the stiffness of the shocks. if u want so adjust the level either get some air shocks or air bags.
i install a Rancho steering stablizer on my friends f150 super crew and it was pretty easy to install. good instructions and all.
for ur last question i believe ur talking about the rear tires rubbing on the fenders.
we had the same problem with my friends supercrew. we put on 33x12.5 super swamper ssr's with only cranking the T-bar. what we did was go down to a metal shop and got some i believe 2"x2" square tubing. we cut them to size, drlled holes and bolted them between the frame and the factory bump stops.
for the front we didnt have any problems rubbing.
Old Mar 25, 2001 | 03:00 PM
ilmagill's Avatar
Post
