endlinks for lowered truck
Hey, sorry if this has been covered. I know there's a wealth of info, but I've searched, and I'm still confused.
I got a set of front and rear sway bars from Addco, but I've got the Western Chassis 2" drop shackles. I read on here somewhere that I can use the endlinks that came with it for up to 2" drops (like mine)... Can I or do I need to find shorter linkd? I plan on talking the guys at AutoZone tonight, and see what's available there, or maybe just calling Addco, but thought I'd start here, and see if anyone has put a rear sway bar on a truck with a 2" rear drop. The front bar is suppose to be just a direct swap with the factory...
I haven't seen anyone on here with Addco bars. Does anyone know of a truck with them? I plan on taking pictures of the bars and the install...
Sorta found my answer. Addco's website says that end links should be as close to vertical as possible with no more than 20 degrees in any direction when sitting at normal height. Guess, I just need to take the new end links to AutoZone, and look for new ones that are 1-1/2" to 2" shorter, right?
