Question... Drop or Lift??? PICS!
What should I do? Raise the front torsion vars to level the truck off? Or should I lower the front using the torsion bars up front (probable about two inches?) and drop the back end about 3 inches? Whats your opinion and what would be the best way to do this? Thanks for your help.
~Colby
Some more pics of the truck with that setup in my Gallery.
https://www.f150online.com/galleries....cfm?gnum=2976
Originally posted by pjf77
Based on this picture I would lower it. By the looks of your rims and the rest of your setup (very nice
) you probably aren't going offroad any time soon. The raising will level you out but I think it would look awkward with that tire/rim combo. Beautiful truck though.
~Colby
I plan to lower my rear end 3 inchs as well i am going to do it by by using shackles and hangers. Put the shackles on the 2" position and the hangers on the 1" position to get the 3 inch drop. THen i think i will have to install a 2 degree shim, then get new shocks, i think im gonna get air shocks(the ones to can raise and lower with an air compressor). Hope this helps.
Thanks that did help. I see you live in socal... Where you getting your work done at? Thanks.
~Colby
~Colby
Lower it, I have a 2wd so did front springs and rear hangers only
The rear hangers lowered my rear end over 3 inches to bring it level
with the 2 inch lowered front end. Here's a B&A shot
'Bout $200.00 for parts
My paln was to have it done by the end of the next school year, so its a while off. But dgoebel is a perfect example of what i am planning on getting and what you said you were looking for Colby. I don't have the money right now(no job yet), but i have been doing alot of research on everything 1 plan to do. i wish i found that dang dog(my buddy found a dog and got a 500 dollar reward and he lowered his S-10 wit that money). But good luck with your truck and it looks awsome!
p.s. Whats the specs on your wheels and tires? sizes? and brands?
https://www.f150online.com/galleries...w.cfm?num=4343
There are some pics of how I want the truck to sit there? Will that look ok? Is that possible and what would I have to do to get it this low? How many inches you think that is? Thanks.
~Colby
~Colby
~Colby
