Sponsored by: CARiD
Rear vibration
Old Feb 12, 2001 | 07:56 PM
pppatlaw's Avatar
Post Rear vibration
I have a new 2001 F150 Supercrew. I notice that at high speeds, 55-65mph, it develops what appears to be an up and down vibration of the rear portion of the truck. It almost seems as if the end of the bed is vibrating up and down. It makes the ride a little roughter and seems to be independent of the road surface. Any suggestions?
Old Feb 12, 2001 | 10:07 PM
truckluver's Avatar
Post
There are latches underneatth your truck on the cab of the truck. You can completely take off the bed and drive the cab with this feature. Check them out and see if they're all the way tight, and if there's nothing that you can see then take it to the dealer and have them check it out for you. Probably not a big deal at all.
1999 super cab
white with tan bottom
automatic
4.6L v8
WAAG grillguard
2 KC daylighters
vampire remote start combo alarm
steelhorse nerf bars
Husky chrome toolbox
2 10" Cerwin Vega subs
pyramid 800w amp
4 pioneer 3 way 6x8's
wants: 2 chamber flowmaster dual exhaust
tan fender flares
american racing atlas
2" fabtech suspension leveling kit
Old Feb 13, 2001 | 11:56 AM
pppatlaw's Avatar
Post
Hi Trucklover: I will check! Thanks for the reply.
Bill
Old Mar 8, 2001 | 09:56 AM
eixster's Avatar
Post
I have a 00 150 and it has the "BOUNCE" from 43-55 I went to the dealer here and they said it is a tire problem and I will have to contact goodyear......Bummer, I will just replace the tires with some meat once I lift it!
Old Mar 8, 2001 | 03:52 PM
pppatlaw's Avatar
Post
Hi Guys: Thanks for your respnses and suggestions. I checked everything very thoroughly and found no loose bed or bad tires. What I did find is a broken tailgate bearing on the passenger side which allows the tailgate to bounce up and down on the passenger side. I have to get it replaced at the dealer at the first service.
Bill
