Sponsored by: CARiD
RCD creaking
Old Mar 8, 2001 | 04:16 PM
blk-s.crew's Avatar
Post RCD creaking
I recently had the RCD lift installed on my SuperCrew and have a anoying creaking noise coming from the RCD blocks and cross-member. The bolts are tight and I can not fiqure out how to stop the creaking. Has anyone experienced this? If so, what did you do to fix the problem. Your help would be greatly appreciated.
Old Mar 8, 2001 | 05:15 PM
BlownF150's Avatar
Post
Mine is getting installed Saturday. How do you like the kit?
(sorry I cant answer your question)
Ryan
2001 5.4
Old Mar 8, 2001 | 05:28 PM
blk-s.crew's Avatar
Post
The kit is very nice. The Bilstein shocks make for a very nice ride, not too stiff. As others on the list have noted, the ride is better than stock. The truck looks great and has gotten positive remarks. The only issue I have is the damn creaking noise. I went with Pro Comp AT 305.17/r16 tires and am happy with them too.
Old Mar 8, 2001 | 07:50 PM
Squanto804's Avatar
Post
Try this test......spray some silicone or white lithium grease into the four areas the torsion bars go into( 2 on the rear crossmember and the left and right lower arm up front) soak it real good. If the noise goes away then its at those spots, but unfortunataly they really need to be taken out and greased with something like axle grease and reinstalled. Mine was doing the same thing and this is what I had to do. Have not had the problem for over a year and a half.
Hope this makes some sense, if not let me know and I'll try to explain it a different way.
Scott
97 F-150 Black, 4x4 XLT ext.cab,sb,w/Offroad Package,
4" Suspension lift, 3" body lift,
4.56 gears w/LS,
Flowmaster 50 Series w/ duals out rear,
36x14.5x16 Parnelli Jones Dirt Grip tires,
16x10 Weld Sidewinder wheels,
Pre-Runner Bumper w/KC Daylighters & PIAA 520 Driving Lights,
Steel Horse Billet Upper and Lower Grilles,
Kodiak Sidewinder Steps,
Pro-Comp Front Skid Plate,
Summit Aluminum Diff cover,
Rancho 9000's w/in-cab remote,
Lift Lips,
Lighted FORD logo,
K&N Filter,
Superchip,
Bosch Platinum +4,
TransGo Shift kit,
Clear corner lenses,
Altezza style Tailight covers,
Bug shield,Tinted windows
Sony ES Mobile head unit,Sony ES Mobile changer,MTX Thunderform sub,Boston Acoustic Pro-Series up front, Polk in rear,PPI & Coustic Amps,Alpine Alarm
Check it out at:
http://hometown.aol.com/squanto804/scottwebpage.html
