Sponsored by: CARiD
Hellwig question
Old Jul 7, 2000 | 10:44 PM
max mitchell's Avatar
Question Hellwig question
A couple of questions for someone who has personally installed #7621 rear sway bar on a 2K 9.75". I saw the "How to pictures", but I could not see this part. Please describe the side frame bracket installation. Please describe areas of installation clearance troubles (ex. ABS wiring, emergency brake line). I saw/understand the brake line change.
Has anyone installed the front #7646 matching unit? Any tips?
Any help would be greatly appreciated. Thanks for your time.
2000 F-150 XL,RC,LB,5.4,4R70W,3.55LS,
Class III tow/Payload #3/Convenience pkgs.,
4-wheel disc/ABS,Chestnut/Parchment 40/60,
Ford bedliner & gas/wheel/spare locks,
3" cold air box modification,Superchip,
Dynomax ultra-flow welded 3" cat-back.
Old Jul 9, 2000 | 10:47 PM
dragonboy's Avatar
Post
Max,
If you havent installed it yet, i'll take a couple shots tommorrow monday and show you.
[img]//www.zing.com/picture/p472c2a8ed68345c4a1da484f368cb219/ff962533.jpg.thumb.jpg[/img]
this one I took today.
Old Jul 11, 2000 | 01:09 PM
Question
ANYONE!!! I don't want to put it on upside down unless the instructions say so. Does it have clearance problems with the ABS/diff wiring? Did you relocate the emergency brake cable on this application? What does the side mount/frame bracket look like and does it interfere with the drivers side frame tubing? I've seen many signatures with this bar on this exact application.
Old Jul 12, 2000 | 07:41 PM
Y2K Hawaiian Lariat's Avatar
Post
Max
As for ABS wiring, emergency brake line, there is no clearance problems. What I did with the parking brake bracket is bend it a little so the brake cable and swaybar don't rub against each other. The long bolts for the sway bar are for 4wd and shorter bolts are for 2wd applications. The driver side mounting bracket is not as difficult as you think it is, just take your time. You'll see the difference when you've fininshed installing the swaybar. Haven't heard of the front unit yet, but changing bushings should be sufficient. Another tip, I suggest you get galvanized washers, stainless washers or spray undercoating on the washers provided because they rust.
Y2K, 5.4L, Black, Lariat Super Cab w/all options, 35" BFG MT's w/ 16.5" by 9.75" Eagle Alloys, 3" Performance Accessories Body Lift, Smitty Built Stainless Step Bars, Hellwig Anti Sway Bar, Hellwig LP 25 Overload Springs,K&N FIPK, Super Chip, Flowmaster Catback, Brahma Camper Top, Herculiner Bed Liner, Rancho Dual Steering Stabilizers
Waiting for Pro Comp Suspension Lift Production Fall/2000
Old Jul 14, 2000 | 12:27 AM
Cool
Y2K Hawaiian Lariat- Thanks for answering my post. So, is it true that the bar has plenty of clearance (mounted above the axle/driveshaft) from the ABS wiring & the extended metal ABS area of the diff? I looked at the area to mount the frame brackets, but what I need to know is: What did you do to rearrange the tubing on the drivers side frame bracket? What does the frame bracket look like/how does it mount? That's a great tip about the washers. Did you have any other problems? What improvements have you had? The front bar is substantially larger at 1-7/16"; Supposedly a matching set of front & rear. I found a good deal on them that expires this month and wanted to analyze the practicality before I bought them. Thanx.
Old Jul 14, 2000 | 01:42 AM
dragonboy's Avatar
Post
[img]//albums.photopoint.com/j/View?u=910999&a=6641845&p=24189369&Sequence=1[/img]
[img]//albums.photopoint.com/j/View?u=910999&a=6641845&p=24189378&Sequence=1[/img]
Old Jul 14, 2000 | 01:45 PM
Cool
dragonboy- Thanks for the pictures. Does that bar go completely above the extended metal ABS area of the diff? Did you re-route any drivers side frame tubing? Did you drill any side mount frame holes on either side?
Old Jul 14, 2000 | 08:09 PM
Post
Max,The bar goes completely above the extended metal ABS area of the diff? There's about 3/4" of clearance between those two components. No re-routing is necessary for the the components near the bracket. And there's factory holes in the frame that you mount the sway bar bracket to.
Old Jul 14, 2000 | 09:26 PM
Cool
Y2K Hawaiian Lariat- Thanks again; I now have exactly the info I was looking for. Time to place my order and pop them on.
dragonboy-Thanx
Old Aug 30, 2000 | 06:58 PM
joegoodrich's Avatar
Question
Max Mitchell,
How did the install go? Where did you get the good deal on the rear sway bar?
Old Aug 30, 2000 | 07:22 PM
Cool
I searched around and found a sale at J.C.Whitney; $110 rear, $120 front. The front got back-ordered until this week. The install was not too bad. The axle brackets need to be rotated up to the 2 o'clock position (if looking at the passenger's rear wheel), so that the bar clears the diff/ABS casting and wiring. A little measuring to center, bending the brake lines, and bending the emergency brake cable bracket slightly. It has plenty of clearance everywhere and has a noticeable change in handling. It also cut down on tire spin around corners. I can't wait to get the front one; this is the one for handling (1&7/16", OEM=1&1/8"). If you have any questions give me a shout. I got another catalog last week that has them on sale again until Oct. 31,2000.
3" cold air box modification, Superchip,
Dynomax ultra-flow welded 3" cat-back,
3" exit Y-pipe, Hellwig rear anti-sway bar.
Old Aug 30, 2000 | 11:14 PM
Post
max mitchell,
Thanks for the speedy reply!
What JCWhitney Part # did you use? I checked their web page and it looks like they are selling them for $134.95. The catalog you have advertising them for $110 sounds like a great deal!
You can email me at joegoodrich@bigfoot.com if you want.
Thanks...
Old Aug 31, 2000 | 01:38 PM
Cool
Your Welcome !
73-00,F-150,2&4 wheel drive,front=code A,#78HJ7401PF,$134.95,sale=$119.95
rear=code F,#55HJ5693A,$124.95,sale=$109.95
I called them and they told me that other members could get the discount also; by mentioning "catalog #118J-07" before 10/31/00. There will be about $20 shipping, and the front one comes directly from Hellwig. Also, they come with a different application specific #, and Hellwig has different application specific #s too. You can order them over the phone at 1-800-837-4227 or 1-312-431-6102.
