Sponsored by: CARiD
Lower Ball Joint - Removable?
Old May 30, 2003 | 12:53 PM
Zerb's Avatar
Question Lower Ball Joint - Removable?
Front end needs work 0 1997 2wd F150. Doing idler arm,tie rods, and lower ball joints, the whole shmear.
Went to ROCK AUTO and ordered all MOOG. I go to the Haynes book, and it says Lower Ball joint is not serviceable - all one unit. Has anyone replaced the Lower ball joint by pressing it out? I can't imagine that MOOG would sell a ball joint that is not removable from the Lower control arm. Can anyone shed some help here?
Old May 30, 2003 | 01:16 PM
AjRagno's Avatar
The 2wd ball joints are serviceable and yes, they do need to be pressed out/pressed in. I couldn't do it on mine so I paid a shop.
Old May 30, 2003 | 01:23 PM
Zerb's Avatar
Thanks for the quick turn around. I have someone in mind to press them out/new in. Did you do the bushings also? How much time should I set aside?
Old May 30, 2003 | 08:15 PM
powerstroke73's Avatar
The lower ones should be servisable. The 4x4 lowers are but the uppers aren't. To my knowledge the 4x2 is the same way. If you pay a shop to do it you're probably looking at $100-200 for the labor for them to tear down the front end and press in new joints. If you do it yourself the only specialty tools you need is a pickle fork (tie rod separator that looks like a giant tuning fork) and the ball joint press. The press is only $20 or so from harbor freight tools and the pickle fork is less than that.
