Sponsored by: CARiD
Leveling Coils
Old Jul 27, 2000 | 04:50 PM
SamDoGG's Avatar
Post Leveling Coils
I was wondering if i put those leveling coils from roughcountry on my 96 F150 4x2 would it raise the front end to the back end, or close? Does it replace the factory coil springs? Do i need to buy anything else to go with the leveling coil, or is that it? Any help would be appreciated thanks .
Old Jul 27, 2000 | 08:13 PM
ilmagill's Avatar
Post
The coils are going to replace the factory ones. I'm not sure but for the new f150 changing just coils doesn't work great, so i take it the 96 is similar. In which case longer shocks are a must, and probably an a-arm kit, but thats normally all included in the lift systems.
1999 4.2l 2wd super cab F-150 3.55 gears LS Mods: 3in body lift, 285/75 R16 BFG AT, suglid tonuea cover (white) 10 disk changer K&N Air Filter Flomaster 40 series Delta Tow package 6000 Lbs GVWR
Things to come: 4.10 gears, Superchip, Grill
ilmagill@aol.com
Superchips in the mail
Old Jul 28, 2000 | 12:07 AM
2fords's Avatar
Smile
Maybe you should consider putting 2 inch drop shackles on the rear? Unless you want that raised look that is what I suggest. They are cheaper and much eaiser to install.
Not sure, but I assume the 96 has leaf springs, inwhich case shackles would work. I'm sure it would handle better than with lift coils.
2000 Sport,Black,5.4L, 3.55 LS,Rear 2in drop, Gibson Super truck, K&N. 86 5.0 Mustang LX w/off road h-pipe, Borla catback, FMS 65mm TB, K&N, 180 Degree thermostat,14 Degrees timing
