Sponsored by: CARiD
Extra Leaf Spring
Old Jun 18, 2000 | 07:20 PM
DarnEFNET's Avatar
Post Extra Leaf Spring
What is this extra leaf spring I seee some people sya they have and where can I get one. I would like to raise my truxk a inch or so when under a load of about 1500lbs
Old Jun 19, 2000 | 01:23 PM
RHuckster's Avatar
Cool
http://www.hellwig.net/
Old Jun 19, 2000 | 04:58 PM
Y2K Hawaiian Lariat's Avatar
Post
I have the LP 25 Hellwigs as well. I've carried loads up to a ton and a half with out any problems. The helper springs will make your ride a little on the stiff side, but well worth it if you use it for loads. Thre's two types of Hellwig Lp 25's progressive and constant load.
Y2K, 5.4L, Black, Lariat Super Cab w/all options, 35" BFG MT's w/ 16.5" by 9.75" Eagle Alloys, 3" Performance Accessories Body Lift, Smitty Built Stainless Step Bars, Hellwig Anti Sway Bar, Hellwig LP 25 Overload Springs,K&N FIPK, Super Chip, Flowmaster Catback, Brahma Camper Top, Herculiner Bed Liner
Waiting for Pro Comp Suspension Lift Production Fall/2000
Old Jun 19, 2000 | 09:44 PM
DarnEFNET's Avatar
Post
Those all look great but I would like to find a single leaf spring that requires me to unbolt my u-bolts and put the spring directly below my top leaf spring. I have seen these on a few trucks but have no idea where to get them. A spring about the same saize as the uppermost spring
Old Jun 20, 2000 | 12:03 AM
RHuckster's Avatar
Post
I'm using the Hellwig 25's, thats 3
extra leafs set up to load only when you need it...when you have a load, can adjust them to come in earlier or later, i've found if you leave them to loose they tend to clunk & rattle so i've got mine a tad bit on the tight side
------------------[list=a][*]All Black 2K F-150 XLT[*]5.4 Auto, 3.55[*]Super Cab, BedLiner[*]Class III Tow Package, Rear Slider[*]Keyless Remote, Cruise, A/C, CD Player[*]Tinted Windows[*]Bug Guard[*]Black Step bars[*]Billet Custom Grill[*]K&N Filter[*]Flow Master Force II Exaust with Single in, Dual out Behind rear Wheels[*]Stainless Hide-a-Hook Tie downs[*]HellWig LP 25 Overloads[*]Front & Rear Color Matched Light covers[*]Dash Cover[/list=a]
Old Jul 17, 2000 | 10:31 PM
AndyU's Avatar
Wink
Just go to your local spring shop. I had three added to mine. Why three? Because I made the mistake of ordering the factory load leveling air suspension. After the truck arrived, I found out it comes with only two leafs if you get the air bags. After the pathetic air system blew out twice and the truck bottomed out from a otherwise completely inadequate suspension, I ripped it out and had three leafs added to my springs to bring them up to standard 250 specs. Cost was about $400.00.
Another very good option from my experience is to add an aftermarket "Airlift" system. They are very reliable (unlike the factory system), and can be inflated as needed to the degree needed. They add anywhere from 2,500 to 5000 extra pounds of capacity depending on the system purchased. Cost of an Airlift kit is $200 - $275.
97 F250 LD XLT Supercab, 5.4 V8, 4x4, Towing, Air Lift, 4 wheel Disk ABS, 3.73 Limited slip, K&N FIPK, payload #2, CD, Navigation System (wife), intruder alert system (two dogs)...
Old Jul 20, 2000 | 10:34 PM
TexasAg's Avatar
Post
I got my add-a-leafs from 4 Wheel Parts for $30 to $40.
