Sponsored by: CARiD
shocks
Old Apr 16, 2000 | 10:13 AM
Road Runner's Avatar
Question shocks
I added a leaf to the rear suspension which lifted my truck 2 inches. Should I put longer shocks on to alow for the extra travel.
1998 F-150 4.2 W/Mod's
K+N air filter,K+N Oil Filter, Redline synthetic motor oil-Transmittion oil-Differential gear lube, Vortex single in duel out rear exit exaust, 4.10 gears,5 speed mtl,265-75r16 Bridgestone dueler AT, Hellwig anti sway bar rear, Add a Leaf springs, brush guard, nearf bars, Pioneer stereo W\Planet Audio speekers,Superchip, Fabtech 2"leveling kit
Old Apr 17, 2000 | 08:21 PM
TexasAg's Avatar
Post
You shouldn't have to. If you went up over two inches you might consider it, but even then it may not be absolutely necessary(depending on how high you went).
Old Apr 19, 2000 | 11:40 AM
Whytknyt's Avatar
Post
Road Runner,
I just did the same thing and had the same question. My truck raised about 1" but already had 4 leaf rear springs. Most of the shocks I have seen are designed for either stock height or 3-4" lift, not much in between. I would think the stock shocks would be OK but it would certainly be nice to have a set of Edelbrock IAS shocks under the rear end!
Y2K F150 SC 4x4
Trition 4.6, 5 sp manual
Tow Package, Factory CD
Sliding rear window, 3.55 LS pumpkins
Mods: Lund Deflecta-shield II, K & N filtercharger
