Lift kit fit
Lift kit fit
im almost postive it will fit but if i can get a good deal on a expy lift and i have a 98 F150 well im just about postive it will fit except for the rear in which case i'll get some blocks or add-a-leaf or re-arch my springs but i felt i would ask first ...one more question are the rear shocks the same length
The front will work but the rear will have to be custom built like you're thinking. Either get an add-a-leaf or replace the rear with 1 new block. Don't stack them, its not a real safe idea, unless you like the idea of your axle walking away from you if it spits a block or it curshes. Stacking dramatically increases the chance of this. As far as the shocks, they should be about the same length.
