Sponsored by: CARiD
Going up how much will I loose
Old Dec 16, 1999 | 12:42 AM
silverback's Avatar
Post Going up how much will I loose
Hey all...final judgement is almost at hand and I have a question for those who have a f150 4x2 4.6l motor. I'm pretty sure unless someone can sway me that I will but bullseye spindles on my truck with a block to achieve a 3.5 in lift. I am also gonna put American Racing Baja rims and 305/70 r16's on her. Since I am so poor at visaulization except in some cases oops sorry...how will she look? I hope she looks good....with 33 inch tires basically how much hp will I loose? The only other mod to her at this point is a 3" pipe from the "Y" on the exhaust back to a flowmaster 50 series and out....what should I expect?
Old Dec 16, 1999 | 11:09 AM
trixman's Avatar
Post
I can still light up my 33's
Old Dec 16, 1999 | 02:05 PM
cphilip's Avatar
Post
My Wife thinks it's better if I "go down".
Old Dec 16, 1999 | 02:59 PM
EXTINGUISHFIRE's Avatar
Post
Well first of all I am pretty sure that the bullseye spindles are only a 3" lift. Secondly, your truck after lift and tires will only be slightly higher than stock 4x with 265/75/17's. I just ordered mine and can't wait to put them on with my atlas rims and 285's BFG's. But make sure that you get the new retooled spindles that use the factory ball joints.
1998 F150 XLT Reg. Cab, STX, White, 4.2 v6, 4x2, K&N, 3.55, Manik grill gaurd, **** Cepek 100 watt driving lamps, Kenwood mask CD-player, drop hitch, Ford hitch insert, 16x8 Atlas rims w/ 285/75/16 BFG All-Terrains KO to be put on when I get the new retooled bullseye spindles
Old Dec 28, 1999 | 07:47 PM
silverback's Avatar
Post
Well the lift is done and 33's are on her....I can't see any noticeable loss in HP's....The lift/rims/tires were worth it.
Old Dec 29, 1999 | 02:00 PM
d reyes's Avatar
Question
silverback,
I have a couple of questions I hope you can answer. Do the spindles move the wheels out?
I'm asking because I've only seen a picture of the spindles & it looks like they would have to move the wheels out to clear the lower ball joint.
Will wheels with 5.5" of back spacing work with the spindles?
Since the wheel is dropped 3" relative to the
upper A arm, how close do your tires come to the arm?
Any info is greatly appreciated!!!
Old Dec 30, 1999 | 01:29 AM
silverback's Avatar
Post
In all honesty I'm not sure... I think you may want to verify the correct back spacing... A place I looked at mentioned I may need spacers in the front if I go with spindles but I opted the for the other....I had a suspension lift installed. I am happy with it besides the fact my truck got broken into today at work...fricken a holes .... The ride is a little stiffer but that's ok ...she looks and feels like a truck!
Sorry I couldnt be much help....
Old Dec 30, 1999 | 03:03 AM
trixman's Avatar
Post
d reyes,
Be sure to buy the alignment cam bolts when you buy your spindles. I had to set the toe in and eyeball the camber before I drove it to the alignment shop.
Chris
Old Jan 18, 2000 | 07:51 PM
ieatdrt's Avatar
Post
as far as losing HP goes...by adding larger tires you should lower the differential gear ratio (numerically higher) in order to compensate for the slower turning larger diameter tires...you won't lose horsepower but you may feel like you lost some off the "oomph" in the bottom end like when starting from a dead stop...but you'll spin lower RPM on the highways at the same speed with larger tires...I'd also install a chip and free flowing air filter to really get the most out of that exhaust upgrade!!...you'll really feel the difference then...
[This message has been edited by ieatdrt (edited 01-18-2000).]
Old Jan 21, 2000 | 12:11 AM
No1Truck's Avatar
Post
I have a '97 XLT 5.4L XC with the 3.5" Fabtech lift, stock wheels and 285/75/R16 BFG All Terrains.(32.8" true height) I also have a 3" after Y-pipe running into 2-chamber Flowmaster-dual 2 1/4" pipes exiting in stock location in front of rear wheel. After adding the 33's, I lost a little grunt off the line. You will probably notice that all the gears seem taller and your acceleration is a little slower, but if you do a lot of highway driving, the rpm's are much more relaxed at 55. Keep in mind that your speedo will be a little off- I ran 255/70/R16's stock and my speedo is slow 10%. (indicated 60, true speed 66, etc.) The Flowmaster sounds great, but I believe I lost a little torque(increased horsepower,lost torque?)on the bottom end. One tip: don't run a 2-chamber Flowmaster exiting in ('97) stock location in front of rear tire unless you want that deep rumble to be felt and heard all the time. I have to turn the radio up a bit on the freeway. Run them out the back and it should be more civilized in the cab.
Old Feb 2, 2000 | 08:07 PM
F150Y2K's Avatar
Post
SilverBack,
Let's see the new wheels on the truck! I haven't checked around to see if you have posted some already, but I would definitely like to see your truck!
Old Feb 4, 2000 | 12:15 AM
silverback's Avatar
Post
Truck is done but dirty ....I will get picture this weekend and post. I like it just need to do a few more things.,.....
Old Feb 7, 2000 | 09:17 PM
silverback's Avatar
Post
here's one picture....the weather is lowsy so it doesnt look anywhere near as good as it did in the sun.
[img]http:\\cochise.uia.net\amraam\truckpic2.jpg[/img]
Also http:\\cochise.uia.net\amraam\truck.htm
When the weather is better I will get more....
[This message has been edited by silverback (edited 02-07-2000).]
