Front Suspension Squeek
OK, here's the symptoms. Mild, fairly high-pitched squeeking from the front suspension area on a straight away when going over small bumps, cracks or expansion joints on pavement. It only happens when the truck/suspension is warm. It sounds somewhat like rubber/metal contact or maybe metal/metal contact. It does not occur off-road or over bigger bumps, i.e. curbs, potholes. I've searched this thread for similar problems and have found loose shock mounts and loose tortion-bar bushing threads. I'll check these out tonight, but does anybody have any other ideas?
Thanks in advance - Reavis
2000 F-150 Lariat SB Supercab 4x4 Off-Road Pkg, Tow Pkg. 5.4L, 3.55 LS rear, Bright Red over Silver, Med. Graphite Guts, Rear Slider, K&N Filter, Cabin Filtration System, Superchip, Mobil 1.
Anyone?
Reavis. I had some anoying squeaks from the front of the truck, but it was most noticible when I came to a stop. Dealer replaced upper and lower ball joints. Now I have a very minor squeak from the rear suspension. Not enough to bother me though.
Henry.
99 F-150 XL 4x4. RC Flareside 4.6 5spd, 3.55LS. gibson 3" cat-back, K&N Gen ll.Westin step bars.Ventshade window deflectors and bug deflector and a cool white shifter ball. The SILVER BULLET. Rock and Roll...Baby!!!
Henry.
