Sponsored by: CARiD
I NEED ADVICE ON A LIFT KIT
Old Aug 3, 1999 | 03:02 PM
RIBADIB's Avatar
Exclamation I NEED ADVICE ON A LIFT KIT
i have a 97 f-150 5.4 lariat 4X4 and i am looking to lift my truck 1-3 inches, i look at some other stuff but they have 4", thats too much for me! i just need to find a company that has it!
please help me on this one!!!
Old Aug 3, 1999 | 03:59 PM
ccla's Avatar
Talking
Well for what I've seen while looking for my lift is that most of the suspension lifts are 4 inches. You could get a body lift in a 2 or 3 inch package. www.performanceaccessories.com Its a hell of a lot cheaper Too. $160.00 or so verses $1200.00 to $1500.00
98 F150 2WD,Bright Red, Regular Cab, 4.2, 3.55, Superchip, 3 Inch Bullseye Lift Spindles, Manik Grill Guard,Nerf Bars, Vent Visors, Fog lights, Kc Lights, Alpine CD Player, 2 Kenwood Amps, Tinted Windows. And Coming Soon: 3 Inch Body Lift Kit, 16x8 American Racing Baja Wheels Wrapped With 33's
And Sooner Or Later A Superchips Decal Or Two
Old Aug 3, 1999 | 08:00 PM
WSECTION's Avatar
Post
you could also crank up the torsion bars an inch and add aleaf or use a 'super spring' setup in the rear. pretty cheap 1"-1 1/2" lift
'97 F-150 4.6L lariat 4x4 flareside. k&n genII, gibson super truck, hella ralleye 2000 lights, JET module,BFG285/75/16 on MT challenger 16x8 wheels, just ordered the JBA coated headers from Steve online
Old Aug 7, 1999 | 08:36 AM
fordfan's Avatar
Arrow
check out----www.tuffcountry.com
1989 F-150 XLT LARIAT 4x4 4.9L I6 5 speed manual tranny 3.55 gears K&N FIPK 3" Flowmaster.
Old Aug 19, 1999 | 12:31 AM
WSECTION's Avatar
Post
loser(you really need a new name!)
I've got 285/75/16 and no problems. If you play offroad you will want to lose the front bumper valence and maybe trim the factory mud flaps
Old Aug 19, 1999 | 12:46 AM
Loser1's Avatar
Smile
RIBADIB-
I know this is a little late, but I just registered. I have the same concerns about a BIG 4' or 5' lift with BIG tires. The problem is I want my rig to still fit into the garage!!!! My plans are to crank up the T-Bars aprox. 2" re-allign the front end and stick 285/75/16 w/AR pythons on. I think this will make the truck look a little more like a 4X.
Old Aug 19, 1999 | 03:27 PM
Loser1's Avatar
Post
WSECTION,
Acceptance is the 1st stage of recovery, or so they tell me. So even if I crank up the T-Bars I'll still need to remove the front valance and do some trimming? Do you know of any other options? I still want to fit in the garage.
99 4x4 XLT supercab 5.4L Flairside, Deep Wedgewood Blue/Med. Graphite w/ Captain Chairs Pioneer DEP-4000, Tint, K&N, Bedliner, 3" Catback w/3 Chamber Flowmaster
Old Aug 19, 1999 | 10:15 PM
DAVENSA's Avatar
Post
Loser, When i had my 79 bronco i had a 4 inch lift with 36s on it and it still fit in the garage...measure from the top of the truck to the garage (7ft i think) you should have room for a 3 in body lift or 4 in suspension lift with 285-295s...ask some guys to messure ther trucks for you.....hope it works out for you.....Dave
1998 F-150, SC/Flairside, 4x2,4.6,auto,3.55s,nerf bars,cls 111 towing,bed liner w/mat,atlas polished wheels w/ 265 scorpions,all plastics guards/bug shields,air raid/k & n filter, superchipped, duals out the back corners, flow master 3 chamber
Coming in Sept..3 1/2 in fabtech lift w/ 3 in spindles and 295 BFG A/Ts.
Old Aug 19, 1999 | 11:00 PM
WSECTION's Avatar
Post
ditto what davinsa said.
I have the 33" tires now, but will be adding a lift for better clearance. as I measure it, I still should get in the garage(7' door) the antenna already hits!
I say go for it and have fun doing it!!!
Old Sep 4, 1999 | 10:12 PM
No1Truck's Avatar
Post
hey loser,
The impression that I got from the description of your truck is that it is a two wheel drive. If this is true, you can forget "cranking up the torsion bars". You can look for them all you want, but you won't find them-2bys have coil springs. My advice is to check out the site "http://www.fabtechmotorsports.com".
I would recommend the 3 1/2 inch lift. Good luck...
Old Sep 4, 1999 | 10:16 PM
No1Truck's Avatar
Post
Whoops, my bad. I must remind myself to look at the truck specs under messages. I was thrown off by loser's previous message-"make the truck look a little more like a 4x".
