Sponsored by: CARiD
Performance Accessories Lift
Old Aug 20, 1999 | 09:04 PM
Deputy's Avatar
Post Performance Accessories Lift
Has anyone installed the Performance Accessories body lift kit? I was looking
into their 3" lift, it's only $130.00 and
I was wondering if anyone has installed this, and if they like it. Also, was is
easy, hard, or did you have someone else do it? I know it includes directions and alot of people do it themselves, but I'm not sure if I could do that, I don't know too much about the under side. But I did install the
westin nerfs myself, so if it's any easier then those I guess I could do it.
Anyone?
97 F-150 XLT 4.6L, Black, S/C, 4x4, ORP, K&N, Chrome Westin nerfs, Omniguard SE bug deflector, Extang snapless tonno, Kenwood CD, Kenwood 6x8's, Kenwood tweeters, Kenwood 300 watt amp, MTX thunderform dual 8's.
Old Aug 20, 1999 | 11:16 PM
Squanto804's Avatar
Post
Hello..I have installed that same kit on my truck. I is a very good,complete kit but is quite a bit harder than installing nerf bars!
It took a couple of nights to do(I did it by myself). Really all that is involed is getting to all the frame bolts in the bed, all bolts in cab(must remove back seat) and a couple up front. Then install the blocks, tighten them down,lower the radiator shroud, add steering shaft extension(kind of a pain), install trans. shift cable bracket(real big pain), and repostion the bumpers.You'll have to adjust the Trans. range sensor and also adjust the shift indicator at the colum. I think thats is about it. I might have forgot something but thats the jist of it. Its not real hard but not a cake walk either.It will go much easier and quicker with some help. Give it a try. Just folow the instuction very carefully. If you have any questions, just ask. Good luck
97 F-150 Black, 4x4 XLT ext.cab,sb,offroad pack.
4" Susp. lift, 3" body
4.56 gears w/LS,Borla exhaust
35" BFG.,16.5x9.75 Weld Scorpio V wheels
K&N Filter, TransGo Shift kit,
Bug shield,Tinted windows
Sony ES head unit,Sony ES changer,MTX Thunderform sub,Boston Acoustic Proseries up front, Polk in rear,PPI & Coustic Amps,Alpine Alarm
Old Aug 21, 1999 | 03:30 PM
Crash's Avatar
Question
I was thinking about getting that performance accessories 3" kit for my 99'. Now does that trans. cable extension, and steering arm come with the kit? Because Iwas on her the other day and saw a truck with 3" body lift and 35" BFG's with no problems. Anybody out there know of frame mount brush guard for the 99's? I like the Smittybuilt, but don't want to drill holes in my bumpers.
99' supercab ORP, double tube chrome roll bars, 4 KC longe range lights, Westin nerf bars, Dual exhaust,Blackouts, Kenwood cd, 12" Orion subs, Orion 2150 amp, K&N
Old Aug 21, 1999 | 06:35 PM
Squanto804's Avatar
Post
Yes, everything comes with the kit. It's not a cable extension but a bracket extension at the trans. and a steering knuckle extension. You'll want to probably puchase "lift Lips" to cover the space between the frame and body(cost about $45). 35" will fit with just a body lift but does not leave alot of room and I personally like the susp. lift w/body lift for the looks and the addit. room. Plus I'm planning on putting 36" Cepeks on sometime. Hope that helps.
Edelbrock IAS shocks ordered
Old Aug 21, 1999 | 11:45 PM
smill's Avatar
Post
I have put this kit on my truck also. If you have the 5.4l motor you will not have to install the transmission range sensor relocation bracket. I am running 35" BFG Mud Terrains with no clearance problems. I have also added a set of add-a-leafs, but I had the 35's on before the add-a-leafs. If you have any questions let me know. You can see my truck at http://www.geocities.com/Baja/Mesa/9131
Old Aug 22, 1999 | 09:01 PM
conqsoft's Avatar
Post
The Smittybilt is frame mounted, and only requires drilling on the frame. It does not mount directly to your bumper, but to a bracket that attaches to the back of the bumper mount. However, if you have a body lift installed, you will probably have to customize the brackets a little.
keith@myf150.com
http://www.myf150.com
Rocky Mount, NC
1999 F-150 XLT Styleside, Black On Black, SuperCab, Short Bed, 4x4, ORP, 4.6L Auto, 3.55LS
Mods: DrawTite Class III Hitch, Smittybilt Outland Grill Guard/Brush Guards, KC Daylighters, Custom Dual Exhaust-Straight Out The Back, Airaid FIPK, SuperChips Chip, Bug Deflector, Pace-Edwards Roll-Top Bed Cover
Old Aug 23, 1999 | 11:48 AM
Crash's Avatar
Thumbs up
Thanks for the info guys! Smill, did you give your torsion bars a little twist? I was thinking of twisting them about an inch, and adding the add a leafs. I'm going to order my Smittybuilt brush guard this week(Chrome or stainless). You two have some sweet trucks, conqsoft, our trucks are identical except I have dark graphite int.
Old Aug 29, 1999 | 11:38 PM
J_Rock's Avatar
Post
Hey Guys~
I have been considering a body lift but I hate they way the lower valance looks when it is cut to fit the frame. If you know what I'm talking about, is there any way around this????
Oxford White 1998 F-150 STX, reg. cab, flareside, 4.2, auto, 3.55s, Prestige alarm, Bel radar detector, Pioneer CD player, 4 Polk 5x7's, Stull billet grille and bumper insert, Flowmaster exhaust, K&N airfilter, V-Tech Tailight Covers(painted to match truck) Clear Corner Lenses FUTURE MODS: I'm to indecisive to know for sure, but a Steeda Sway Bar and Superchip are in the near future.
Old Sep 2, 1999 | 11:23 AM
Crash's Avatar
Question
Anybody know if 33x14.50 **** Cepek Fun Countries will fit with the body lift. Because Tyres International has four for $400, I'll be putting them on Weld Scorpio wheels. I trail ride, go duning, and a little bit of mud, just don't want them to hit when I'm fully turned.
Old Sep 2, 1999 | 10:04 PM
Squanto804's Avatar
Post
Yeah, they would fit but I would absolutly put the body lift on for clearence reasons since you do go offroad. Plus they are a wide tire so you probably wont get the turning radius like you have now. It will look great though.
35" BFG.,16.5x9.75 Weld Scorpio V wheels, Edelbrock IAS Shocks,Lift Lips,
Old Sep 3, 1999 | 12:52 AM
mudder's Avatar
Thumbs up
I'm pretty sure they would fit with a body lift. They might even fit without one, a lot of guys here are runnin 33's with no lift and have no problems.
Stone Cold, Black 98 Styleside S/C F150 4x4 0RP 5.4 3.55ls,Magnum bug shield,Grizzly roll bar,
2 Baja lights, 4 165 watt KC lights (fun to play with on weekends), Manik grille guard,Westin step bars,Sonic aluminum treadplate 36" tool box, Flowmaster dual exhaust, K/N air filter, 265/75/16 BFG AT/S, American Racing Baja wheels, a F150 Online sticker, and a Stone Cold sticker on the front windshield.
. More to come for Stone Cold: Ramsey winch will be on it real soon (hopefully), 2 more KC lights, Rancho shocks. If you would like to see pics, email me at mudder46@hotmail.com or see pics at http://members.aol.com/polokid54/fpic.html
Old Sep 5, 1999 | 12:20 AM
Crash's Avatar
Thumbs up
Thanks guys. Most of the off-roading I do is at Silver Lake dunes, just want to be able to turn without tearing up the fender. As soon as I get things together, I'll post a couple of pictures. Thanks again.
