Sponsored by: CARiD
FX4 suspension
Old Mar 16, 2003 | 05:54 PM
detroitford's Avatar
Registered User
FX4 suspension
How has the FX4 cv axle suspension been holding up when off-roading when compared with the older solid axle suspension?
Old Mar 18, 2003 | 02:23 PM
JMC's Avatar
JMC
25 Year Member
As far as I know the Fx4 system is the OEM 97+ IFS with white Rancho RSX shocks. If you want to know how this system stands up to Off road use comapired to A solid axle then I would say that the CVs can not handle anything larger than a 35 inch tire. At high speeds the ride is smoother and better controlled. Articulation is not as good as a solid axle but it can be close stock to stock if you disconnect the sway bar.
Regards
Jean Marc Chartier
Old Mar 18, 2003 | 02:37 PM
Registered User
Thanks, I was looking towards the future as far as how I could go with a lift and tires with those CV axles.
