Sponsored by: CARiD
Popping noise in rear at slow speeds
Old Mar 7, 2003 | 12:37 AM
dtclements's Avatar
I hear a loud popping noise when making a sharp turn at slow speeds, like turning into my driveway. Noise is coming from rear, sounds like passenger side. Usually happens when hitting a bump at slow speeds while turning.
Any ideas?
thanks
Old Mar 7, 2003 | 07:13 AM
SlickRick150's Avatar
i think my truck does the same thing. it's like when i'm turning sharp and going up a steep little hill (such as a driveway or parking lot) it makes 1 pop in the rear on the passenger side. i don't know what it is, just thought i'd share that i think i have the same thing.
Old Mar 8, 2003 | 08:13 AM
Deeno's Avatar
Does your truck have a locking differential? I used to own a Chevy with a locker, and got a popping noise from the rear at low speeds. The service guys said it was the lock-up clutches in the rear end. The solution was to change the differential oil routinely, and use a formula special for lock-up clutches.
Old Mar 9, 2003 | 01:51 PM
robstaxi's Avatar
I'm also have this poping problem but mine is coming from the drivers side... going over some small bumps at slow speed's...and it's driving me nut's I had the dealer check out the body mount's and they checked out fine..I would also like to find what is causing this problem
Old Mar 9, 2003 | 02:05 PM
robstaxi's Avatar
by the way my truck does not have a LS
Old Mar 12, 2003 | 04:15 PM
SweetSilver's Avatar
I am having the exact same problem you guys are describing. I had a dealership look at mine and they couldn't find anything wrong. What drives me crazy about it the most is that I SWEAR it does it more when it is raining or wet outside.
Old Mar 16, 2003 | 12:07 PM
robstaxi's Avatar
I was wondering if all you guy's own a flairside....mine is a flairside
Old Mar 17, 2003 | 07:12 PM
GEEMAN's Avatar
Unhappy
My 2002 s/c fx4 does the same thing. I also took mine to the dealership. They told me they all make a little noise, It's normal Sometimes I believe they are the
I guess we're going to have to live with it.
