What gears with 2003 'crew?
What will accelerate better, a 2003 'crew with a 5.4L, 3.55 gears and 245/75-16 rubber, or the 3.73 and 265/70-17? I come up with an rpm, in od at 62mph, for the 3.55/245 combo at 1,694rpm, and the 3.73/265 combo at 1,724rpm. The 3.73/265 combo is a bit lower, but has larger tire mass which may hamper the advantage. Maybe a 3.55/255/70-16 combo, which should be 1,780rpm? Any input would be appreciated. Thanks.
I wish I had gotten the 3.73's
My has the 3.55LS and while it is powerful and very capable, I can tell that the 3.73's would be stump-pullin strong with the the 5.4 while towing... Really does well above about 1800 RPM's and I can't complain with the highway towing w/OD off, i just think the 3.73's would give it a little more umph if ya know what I mean...
Chris (ReelWork)
Chris (ReelWork)
My 01 SCrew was a 5.4L w/3.55 rear end, 17" tires & wheels. I now have a 03 SCrew with 5.4L w/3.73 rear end, 17" tires & wheels. There is a noticeable difference for the better in the 03 SCrew. I would say go with the 5.4L - 3.73 - 17" option.
Thanks alot!
I priced out an 2003 4x4 XLT FX4 with 5.4L/3.73's on saturday. The salesman had trouble figuring out all the new 2003 codes and combinations to suit my option load, but all in all, the 3.73/265-17" package is legit. He dug around for awhlie, figured it out, and it worked. From what I can tell, the 3.73's are standard with the Lariat package because the 17" rubber is standard with the Lariat. The 3.73's come with the FX4 pkg due to the 17" that come with the pkg.
Definatly get the 17"s with the 3.73s. You may not get as good of gas mileage but you will have better acceleration.
I wish my truck had the 3.73s but unfortunatly for me to change out the gears would just be too expensive, I will wait for the 2004s when they also upgrade the engine.
Also ZYG if your still out there, what do you think of the procomp mud terrain on the 17" wheels? I am thinking about getting them myself but am concerned about wear, noise, gas mileage, and performance. If it only effects these a bit then I can live with that. Did you notice a big diffrence with those tires in any way? Please let me know much appreciative.
Of course its "legit"! I am driving my 2003 SCrew XLT FX4 with 5.4L V-8, 17" tires and wheels, and a 3.73 limited slip differential, and have been for exactly 128 miles. I again went with an XLT because I did not want leather.
If you order the FX4 off road equipment package (code 55R) you will get P265-17 OWL ALL- TERRAIN TIRES; 3.73 LIMITED SLIP AXLE, SKID PLATES; 17' CAST ALUMINUM WHEELS; AND RANCHO SHOCKS. This is not Ripley's Believe It Or Not; this is a fact.
My 2001 4X4 Screw XLT had the 3.55 rear axle w/ 17 inch tires. Believe me there is a noticeable difference. By the way I don't believe the 3.73 is available in a 4X2 but on that point I may be wrong.
MTNMIKE... Question fer ya...
I have an 2002 FX4 and are you saying that it should have 3.55's... Becuase I looked at the sticker and it shows 3.55's but, if the FX4 is 3.73's then that's great!
Enquiring minds want to know...
Chris (ReelWork)
Chris (ReelWork)
