SuperCrew
Question regarding Stock CD player for a 2001 SCREW
Old Feb 18, 2002 | 09:28 PM
Aidden's Avatar
Angry Question regarding Stock CD player for a 2001 SCREW
If I play CD's while the heater is cranking out the warm air, the CD player will shut down from overheat in about 10-20 minutes.
Has anyone else experienced this?
The system is the stock in dash CD player. Operates fine other than this issue.
Old Feb 18, 2002 | 09:32 PM
scooksey's Avatar
I've read on this board where others have had the problem, and Ford has corrected it... there may even be a TSB out on it. I've not had the problem, but I have a 6-CD changer.
Good luck
Old Feb 18, 2002 | 09:37 PM
xole's Avatar
There was a re-design that added a fan to the factory in-dash cd player for the problem you are describing.
This is a fairly common problem and your dealer or Visteon repair center should be aware of it.
Good Luck!
